How much does a valve clearance adjustment cost?
Old Nov 20, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
How much does it run at your dealer? I don't have a garage and it's November in Ohio, putting this out of DIY territory for me right now.
Old Nov 20, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
Around $100.
Old Nov 20, 2004
streetglower's Avatar
Originally Posted by Sickboy
Around $100.
****, I bet it is way more then $100. It cost $100 just to have honda look at your car, now imagine them having to take off your valve cover and what not and adjusting each valve, I say more toward several hundred $$$.
Old Nov 20, 2004
Sickboy's Avatar
I called a few days ago actually. Cheapest was $90, Most expensive was $125 including the valve cover gasket. This was for the g/f's Accord if it matters. I'm just going to do it myself, but I don't feel like doing the timing belt ~400$
Old Nov 20, 2004
VTEC01EX's Avatar
I guess if it's $90-100, that's not too unreasonable considering it's pretty involved. The last thing I need is to get the valve cover off and have it start raining (or snowing). Thanks for the info!
Old Nov 20, 2004
I don't know if you need a valve adjustment, but mine is fine and I'm close to 30k miles. Honda says every 15k tho for adjustment.
Old Nov 20, 2004
VTEC01EX's Avatar
I'm at 38K, and the car sounds more like a sewing machine all the time. Based on other stuff I've read about valve adjustments, this sounds like a symptom of needing one. The car's running fine, just sounds a little off.
Old Nov 21, 2004
vtecpimp's Avatar
vtecpimp is an unknown quantity at this point
When I had my 99 Si, I got my valves adjusted at 60k miles and it cost me three hundred doallrs at the dealership ( if I remember right )
Old Nov 21, 2004
vtecpimp's Avatar
Where in any manual for honda does it say routinely adjust your valves, it says adjust only when noisy, if you are getting yours serviced that often, you are wasting money and someone is lying to you
Old Nov 21, 2004
I've never had the service. I prolly would even do it myself, since you just need to buy the feeler tool. I have official maintenance booklets from the dealer and it says valve adjustment every 15k. Someone said if the engine is noisy, it's already too late for adjustment. I know a few people who waited and the adjustment didn't help the noise at all.
Old Nov 21, 2004
VTEC01EX's Avatar
Other than noise, what problems would incorrectly adjusted valves cause? That's really my main concern, if it sounds like a sewing machine forever I guess it's not the end of the world.
Old Nov 22, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
Aren't the lifters hydraulic??? If so, they should need adjusting very often if at all. If you start hearing noises (really obvious noises), it's may be a collapsed lifter.
Old Nov 23, 2004
a-lo's Avatar
a-lo is an unknown quantity at this point
a valve adjustment should cost 1.5 hours of labor, $$$ depends on the shops labor rate. My dealer's lbr rate is $98/hr. I'm in MN so maybe. May be diferen't elswhere.
Old Nov 23, 2004
a-lo's Avatar
if the valves are too tight it could cause map sensor #s to be too high.
Old Nov 23, 2004
djmota's Avatar
nope they are mechanical roller rockers directly on top of the cam.
Jul 12, 2015 11:54 AM
Ccoop87
Jul 9, 2015 03:26 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
AaronSorenson
Jul 7, 2015 09:40 PM
SpecialRequest
Jul 7, 2015 07:52 PM
