t-70 turbo.... lack of hp #'s
So our shop car is running a 255 Walbro Fuel Pump, JLM t-70e turbo kit with a sparco FMIC.. a few other bolts ons and its only laying in around 265 whp. WTF.. 15 psi.. what is the problem here?? You guys think that the injectors are to small. ??
you are not gettin good HP cause the max HP is way past your redline. the turbo isnt even fully spooled when you hit redline with a turbo that big.
i agree, your using a turbo thats way too big for your application. the biggest isnt always the best. i would work with different combos of what you have laying around and find something that spools quicker and provides the best boost to redline
7thgen Power Maker
Not to flame...........but it is a Spearco Intercooler not Sparco like the seats
What size injectors? I hope not the stock 240CC injectors..........
What motor? I hope not a D17.......That turbo is WAAAY too huge for the 101.7 CID we have.......Not to mention, even at 15 PSI on that turbo, there must be some crazy compressor surge and immense heat.........that turbo is meant to be operating at 2 BAR plus..........Look @ the compressor map.
Lag...........you would have to have literally 10,000 RPMS of rev in a D17 to see somewhat decent power through less than half of the RPM band...............
7thgen Power Maker
Originally Posted by Atticus
i agree, your using a turbo thats way too big for your application. the biggest isnt always the best....
7thgen Power Maker
Originally Posted by truehonda
This definatley is not a d17 no way. Doesnt even sound like a honda
Originally Posted by SpeedXtasy
My name is scott, im the president/ceo of a tuning shop here called SpeedXtasy Tuning. My project car is most likely going to be a 03-04 coupe. Im just here to lounge around and chill, i already know what is getting done to the car, i am just finding out things that work the best through your guys's trial and error
That turbo is too big for any Honda 4 cylinder, unless that motor is built to be strong and to rev to a stupid high rev limit.
Unless you're building a drag only car that you can use a 2 step to spool at the line and nitrous, you're wasting a lot of time and money with a turbo that big.
b18c 15psi on a normal common basis i would sa well over 300, built of course, but using such a huge race turbo is not in ur best interest
Turbos, Engines, Chassis and Suspension Tech
B18C1? B18C5? What? Be a little more specific. Generally on 15lb/in^2, a B18C* will make around ~300hp. Varies with setup. Before I can help you, you need to specify what you have.
NROD315
Sep 23, 2015 03:46 PM
soufigured
15
Aug 18, 2015 08:22 PM
shredding tires if fun...its the torque that makes you win races...power is pointless if you cant put it to the ground
