t-70 turbo.... lack of hp #'s
Old Nov 19, 2004
SpeedXtasy's Avatar
SpeedXtasy is an unknown quantity at this point
So our shop car is running a 255 Walbro Fuel Pump, JLM t-70e turbo kit with a sparco FMIC.. a few other bolts ons and its only laying in around 265 whp. WTF.. 15 psi.. what is the problem here?? You guys think that the injectors are to small. ??
Old Nov 19, 2004
SpeedXtasy's Avatar
its being tuned with a greddy e-manage.
Old Nov 19, 2004
abmerop18's Avatar
Jam out with your clam out.
problem? that turbo is huge. lag is probally killing it and its not boostin till like 5500+ rpm i bet
Old Nov 19, 2004
abmerop18's Avatar
just a little big i might say
Old Nov 19, 2004
SpeedXtasy's Avatar
Right but that doesnt explain the lack of hp #'s. I choose a big turbo on purpose. That way i can race on a street tire and not blow the tires off the line.
Old Nov 19, 2004
abmerop18's Avatar
you are not gettin good HP cause the max HP is way past your redline. the turbo isnt even fully spooled when you hit redline with a turbo that big.
Old Nov 19, 2004
SpeedXtasy's Avatar
I think i may swap the turbo out tonight for a big 16g
Old Nov 19, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
What kind of motor is it?
Old Nov 19, 2004
civicskater's Avatar
Chicks dig my scent
shredding tires if fun...its the torque that makes you win races...power is pointless if you cant put it to the ground
Old Nov 19, 2004
Atticus's Avatar
Atticus is an unknown quantity at this point
i agree, your using a turbo thats way too big for your application. the biggest isnt always the best. i would work with different combos of what you have laying around and find something that spools quicker and provides the best boost to redline
Old Nov 19, 2004
dezod's Avatar
7thgen Power Maker
Not to flame...........but it is a Spearco Intercooler not Sparco like the seats
What size injectors? I hope not the stock 240CC injectors..........
What motor? I hope not a D17.......That turbo is WAAAY too huge for the 101.7 CID we have.......Not to mention, even at 15 PSI on that turbo, there must be some crazy compressor surge and immense heat.........that turbo is meant to be operating at 2 BAR plus..........Look @ the compressor map.
Lag...........you would have to have literally 10,000 RPMS of rev in a D17 to see somewhat decent power through less than half of the RPM band...............
Old Nov 19, 2004
dezod's Avatar
7thgen Power Maker
Originally Posted by Atticus
i agree, your using a turbo thats way too big for your application. the biggest isnt always the best....
In the words of Corky Bell.........bigger isn't always better, it is just less planned out.
Old Nov 19, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
This definatley a d17 in every way. Sounds like a Honda SOrry that was for paul
Old Nov 19, 2004
dezod's Avatar
7thgen Power Maker
Originally Posted by truehonda
This definatley is not a d17 no way. Doesnt even sound like a honda
Originally Posted by SpeedXtasy
My name is scott, im the president/ceo of a tuning shop here called SpeedXtasy Tuning. My project car is most likely going to be a 03-04 coupe. Im just here to lounge around and chill, i already know what is getting done to the car, i am just finding out things that work the best through your guys's trial and error
Eddie you wanna retact that statement?
Old Nov 19, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
t-70e on a d17 motor
Old Nov 19, 2004
SpeedXtasy's Avatar
if i told u you wouldnt belive me.. so ill get some pictures up soon
Old Nov 19, 2004
SpeedXtasy's Avatar
b18c
no joke
Old Nov 19, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
That turbo is too big for any Honda 4 cylinder, unless that motor is built to be strong and to rev to a stupid high rev limit.
Unless you're building a drag only car that you can use a 2 step to spool at the line and nitrous, you're wasting a lot of time and money with a turbo that big.
Old Nov 19, 2004
drjvic04's Avatar
drjvic04 is on a distinguished road
Old Nov 19, 2004
drjvic04's Avatar
Old Nov 19, 2004
C2i0v0i1C's Avatar
SuperMODrizd
b18c 15psi on a normal common basis i would sa well over 300, built of course, but using such a huge race turbo is not in ur best interest
Old Nov 19, 2004
B18C1? B18C5? What? Be a little more specific. Generally on 15lb/in^2, a B18C* will make around ~300hp. Varies with setup. Before I can help you, you need to specify what you have.
Old Nov 20, 2004
Chicks dig my scent
someone got hold of a import tuner magazine and just started saying he has parts they randomly put throuhgout the mag
Old Nov 20, 2004
abmerop18's Avatar
^ lol
Luluharp
Sep 27, 2015 11:56 AM
speedlever
Sep 24, 2015 07:18 PM
NROD315
Sep 23, 2015 03:46 PM
soufigured
15
Aug 18, 2015 08:22 PM
