h&r
Old Nov 18, 2004
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
h&r
how does everyone like the h&r springs?
Old Nov 22, 2004
04RedCiVP's Avatar
Every predator is someone elses prey!
04RedCiVP is an unknown quantity at this point
I loved mine (ride quality is quite comfortable) ---> HOWEVER, they were not low enough for me (only 1.3" drop)
Look below....
Old Nov 23, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Very comfortable and perfect drop if you have a coupe, highly recommended for that application. On a sedan, your rear sags too much and the rear shocks blow rather quickly. I speak from experience.
Old Nov 23, 2004
silvrbreez02's Avatar
silvrbreez02 can only hope to improve
Telly: I'm putting the kit on my car in about 2 weeks. Did you get a camber kit for your H&R drop? Would you recommend it? Thanks bro.
Old Nov 23, 2004
TeLLy's Avatar
I didn't need a camber kit even with over 2.5 degrees camber in the rear. Fronts were OK for camber, but neither front nor back tires showed any camber wear when I took them off. I don't think I'm ever going to buy a camber kit unless I go so low I need to tuck the rears in (dial more camber).
Old Nov 23, 2004
Echoed my thoughts man. Thanks for the quick reply, I appreciate it.
Old Nov 24, 2004
EL_03's Avatar
EL_03 is an unknown quantity at this point
Like Telly said, I am experiencing the same problem, other wise they are good springs!
Old Nov 24, 2004
dvsdara's Avatar
dvsdara is an unknown quantity at this point
If you're looking to buy a set, shoot a PM over this way. I have a set for sale. Only used for 2 months before I swapped in my B&G S3's.
