h&r
Yes, it's an Acura EL
Very comfortable and perfect drop if you have a coupe, highly recommended for that application. On a sedan, your rear sags too much and the rear shocks blow rather quickly. I speak from experience.
I didn't need a camber kit even with over 2.5 degrees camber in the rear. Fronts were OK for camber, but neither front nor back tires showed any camber wear when I took them off. I don't think I'm ever going to buy a camber kit unless I go so low I need to tuck the rears in (dial more camber).
