Front Strut Bar; Neuspeed
Hey Ya'll I just got a Front Strut bar. For some reason it doesnt line up with two of the links. It's coming off of an 01 EX and mine is 02' anyone got any ideas? It would be great! Thanks!
Yeah lift one side up if you must. Try putting the opposite side on first. I remember that switching the order and tapping it with a rubber hammer worked. I didn't have to jack the car up either.
Put one side on loosely, then raise the whole front end. Line up the other side, bolt it down, lower the car, torque both sides to 33 ft-lbs.
hehe its neuspeed season
i got mine in today.. but it was dark by the time ups got here.. i put mine on over the nuts and it was off by atleast an inch.. so im gunna try the whole jacking it up thing tomorrow..
the instructions say that if it still dosent fit to loosen the third nut... .. .so just to be safe.. umm.. its not gunna like.. fall off or anything if i do that when the cars jacked up is it?
fyi they have been showing up on ebay a lot recently.. i got a polished one for 108 shipped.. and a black one for 104 shipped..
the polished one wasnt suposed to be polished.. so that had to go back..
the polished one i got and sent back.. it was in fine shape.. polished
no im not the one selling it
ok i can not get one hole to line up at all.. drivers side rear... ive jacked the car on both sides.. loosened all the other nuts up so they are almost off.. wiggled the bar around.. yanked on it.. had someone sit on one side while the other side was jacked up and no matter what i can do it will not go..
the closest i can get the bolt right to the edge of the hole.. but it just wont go in
heeeeeeeelp!
heeeeeeeelp!
ok i got it.. my friend left but i got it alone.. good friggin god what a process.. i dont know why i didnt think of this when he was still here.. it would have taken like 2 seconds..
if you run into this problem.. have someone pull up on the middle of the bar (if they are short use yer belt).. then with yer foot push the bar in the direction it needs to go.. then with a block of wood and a 3lb sledgehammer give it a good wack and it will pop right on
"if it dont work, get a bigger hammer"
hehehehehe
hehehehehe
GH04si
Apr 15, 2015 08:13 PM
