s2000 steering wheel
Old Nov 15, 2004
Da1lyDr1ver's Avatar
Smile s2000 steering wheel
if i were to buy a S2000 steering wheel without the airbags, could i put our stock airbag unit into the s2000 steering wheel? anyone know if its a perfect fit? thanks
Old Nov 15, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I doubt it.
Old Nov 15, 2004
Pharoh's Avatar
Bobaganoosh!
I seriously doubt it. I wouldn't mess with the bags like that anyway. Go with what it comes with or foget it imo. My SiR wheel has the one it came with and I wouldn't want to risk anything else.
Old Nov 15, 2004
king of 42o's Avatar
king of 42o is an unknown quantity at this point
hey man have a s2k wheel and the civic bag unit doesnt fit.
Old Nov 15, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Just buy an s2k wheel with the airbag...
If your planning on doing the s2k steering wheel swap, your going to need to know how to re-wire the airbag controls and cruise control. They both have different harnesses... It can be done though....look in my member's ride gallery...
Old Nov 15, 2004
Pharoh's Avatar
Bobaganoosh!
Yup...well, my SiR wheels air bag was compatible but the Cruise wasn't.
Old Nov 15, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Yup- on the S2k wheel you go from a 4 plug harness to a 2 plug harness (or visa versa) and you must rewire for them to fit... And since I chose to use the s2k wheel's cruise control (2 switch vs. civic 3 switch) you had to rewire as well.
I was just thankful my friend is a Honda-tech and knew how, lol.
Old Nov 15, 2004
thanks for your help guys. i was just curious because i saw a S2000 steering wheel for sale on ebay minus the airbag unit.
does anyone know if the '02 and up civic SI steering wheel or the RSX steering wheel will fit our cars without mods? thanks again.
Old Nov 15, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Will fit. I've got an RSX wheel on my own ride (see my member's ride gallery). You may have to cut and splice airbag wiring, depending if you have one or two airbags, but otherwise it's a perfect fit.
Old Nov 15, 2004
Pharoh's Avatar
Bobaganoosh!
not sure if u know that the Si (US) is the SiR (Canada). I have the SiR wheel and the airbag it comes with will connect to your harness. The Cruise will not. Best/easiest thing you can do is run the OEM cruise and switces somewhere else in the car....like by the emergency brake.
Old Nov 15, 2004
TeLLy's Avatar
My cruise plug from the RSX didn't fit into my EL one either, but I just took the wires from the RSX cruise unit and spliced them into the EL cruise harness's wiring and taped it up. The huge RSX cruise controls (compared to my old ones) are much better and all 3 buttons work so I'm happy.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
GotSiR
Jun 23, 2016 04:06 PM
alaga
25
Aug 13, 2015 04:42 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
qlitten
Jul 21, 2015 03:12 PM
