Questions On turbo install.
Old Nov 9, 2004
HyaBoosta's Avatar
This thread is here to help me and others to come with any questions that may come along with installing a custom set up themselves.(I checked the Sf install thread but it wasn't much help to me.) Well to kick it off right I have a question. W
What strength bolts did you guys use to mount the manifold to the block,turbo to manifold? were the stock bolts used or new ones?
Old Nov 9, 2004
tfnaaf's Avatar
BLDNPSI Mod
Im not sure of the metric equal but grade 8 or better id suggest. I have a question concerning what size of oil return line #8 or ???
Old Nov 9, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
anythin 8 or above..
Old Nov 9, 2004
An I used new bolts but longer one since the flange on the turbo is really thik..
Old Nov 9, 2004
HyaBoosta's Avatar
good info. Does anyone have the english instructions to an HKS type 0 turbo timer. Mine came in but it's all JDM.
Old Nov 9, 2004
civic01vtec's Avatar
I used the stock bolts.
some tips........it helps to have a extra hand. Make sure u have a checklist to make sure everything was done. Test fit the turbo/mani to see if you have to rotate the compressor housing.
Blah, u will learn
oh, and i hope your car isn't a daily driver
Old Nov 9, 2004
HyaBoosta's Avatar
yeah my car is a daily driver but im going to do the install on all the simple things then flat bed it to SFP to put the final touches on it and tune.
Has anyone relocated the IAT sensor to right after the filter and before the turbo? I am going to do it becuase of the preset location on my charge pipes by SFP. all i need to do is use the same gauge wire and soder it and extend it down right?
Old Nov 9, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
You need to have the IAT by the throttle body. The reading will be inaccurate by the turbo.
Old Nov 9, 2004
tfnaaf's Avatar
BLDNPSI Mod
I could be wrong , but i think mounting it after the turbo will read too high a temp and will adjust timing and fuel the wrong way that would be ideal.
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
