Clutch Install Tricks
Old Nov 2, 2004
HyaBoosta's Avatar
Hey I already know that changing the clutch is a pain on our vics. I already had to swap my tranny. I know your supposed to pull the subframe ect. but has anyone changed the clutch without dropping it? How did you do it?
Old Nov 2, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
i had to drop mine the only thing i didnt separate was the shock/spindle from the subframe and just laid it on the ground.
but it wasn't worth it, but make sure u have a big enough ball joint separator for the bottom 1, its bigger than ur standard separator.
Old Nov 2, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Slide the tranny to the side and secure it there. There is plenty of room to work.
Old Nov 2, 2004
HyaBoosta's Avatar
has anyone else tried the slide to the side approach. I'll give it a try this time.
Old Nov 2, 2004
Your Parts Guy
Just pull out before its too late HAHAHAH
Nah for real, slide to the side works very well.
Old Nov 4, 2004
aftershockcivic's Avatar
aftershockcivic is an unknown quantity at this point
thats how I did mine.
Old Nov 4, 2004
opto_isolator's Avatar
The hardest part was aligning the spline to the clutch AFTER the clutch was installed - if you don't line it up perfect, its not going to go on....
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
Blazz
Jun 4, 2015 01:04 AM
bsmiley
Apr 27, 2015 01:27 PM
meels808
Nov 20, 2001 09:37 AM
