one small subwoofer up front?
Old Nov 1, 2004
Adawg's Avatar
Adawg is an unknown quantity at this point
would it possibly add good midbass to have a single 6.5" sub installed in the front of my car with my 6.5" seperates. Like myabe in the dash on one side or somethign?
Old Nov 1, 2004
civic01vtec's Avatar
possibly yes..........but it would be better to get a EQ to tune.
Old Nov 1, 2004
IronFist's Avatar
Post pics if you do.
What size box would a 6.5" sub need?
Old Nov 1, 2004
MegaHurtz's Avatar
A guy I know put a 6.5" woofer in his dash and he said it sounds sick. He said it was a lot of work but wasn't that hard, took a full weekend. Use a good quality woofer and you can get hte asme. I am not sure what he used for an enclosure but I think it was a very small ported enclosure..
Old Nov 1, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
I was thinking of trying to cram an 8 up front, more than likely in the center of the dash, under the window. That is till I looked under where I wanted it. Honda and their crap they stuff up in there. If I had an auto, there'd probably be a 6.5 or 8 in the center console.
Old Nov 1, 2004
MegaHurtz's Avatar
I was offered a nice pair of MBQ 8" drivers the other day that my buddy wanted to install in my front stage but they were just too big to go anywhere, of course these were subwoofers, not midbass or whatever
Old Nov 1, 2004
fonto's Avatar
The LA Clipper
Focal makes a 5" "subwoofer" ...you can prolly get one of those to fit in the center console...but it would definantly need to be in a sealed or ported enclosure (no free air).
Old Nov 2, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I can't picture what it looks like, but how much space is there behind the glove box? I wonder if one might be able to fit the 5" in the dash by building the glove box (obviously behind the actual glovebox) into an enclosure? How much volume is that 5" looking for?
Old Nov 2, 2004
PunkingCivic's Avatar
I need TP for my bunghole
if you install the 6.5's in the dash aimed at the windshield it will raise the output by 3db when reflecting off of glass.
Old Nov 2, 2004
MegaHurtz's Avatar
There is no space behind the glovebox whatsoever... if you are going to build UNDER the dash do it on the drivers side where there is some space
Old Nov 2, 2004
you could take the passanger air bag out and fab a speaker mount there.
Or fabe a mount for the area behind the cup holder.
Here is a diagram of the dash for a 01 civic coupe
Old Nov 2, 2004
brash's Avatar
brash is an unknown quantity at this point
If you are looking to get better midbass, I would not install a single channel subwoofer. While most bass sounds are mono (left over from vinyl records, I believe -- stereo bass would cause the needle to jump), midbass sounds are typically in stereo. If anything, I would add a speaker for each channel.
But what do you mean, exactly, by "better"? That is a subjective term... Do mean better quality? Louder? Something else? If you are looking to get better sound quality, I wouldn't bother adding another speaker up front. If you are trying to make up for crappy front midbass speakers, you are still outputting sound through the crappy fronts... why not just replace them? And if you already have good fronts, adding more speakers isn't generally going to improve the sound quality. It might even make it worse.
Ma213802
May 18, 2015 07:01 AM
WLakers
May 4, 2015 06:23 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
locozoko
Apr 6, 2002 09:00 PM
