Car not starting if not in 'Park' completley
Old Nov 1, 2004
hustlelikem0fo's Avatar
And no god forbid you thought this is about the civic haha
The Maxima beater I got for the winter, I noticed a weird boo boo.
When the shifter is in 'Park' but its a little closer to the 'R' the car doesnt start. I turn the key and all I hear is click click click.
Then I take the shifter and slightly push it up away from the 'R' gear completley into 'P' and then the car starts normally.
I know this isnt about the Civic but I was hoping someone with a little mechanic knowledge could tell me what this could be...... I'm assuming its some safety feature that wont let the car start if its in Reverse. If it is a safety feature why does moving the shifter like half and inch up or half an inch back arms and disarms the safety feature?
Here is a pic of what I mean
Old Nov 1, 2004
Zzyzx's Avatar
Autocross Junky
Its a safty feature found on ALL automatic transmissions.... It basically stops you from starting the car if its in gear. The car should be able to start if its in N though.
Old Nov 1, 2004
I just went outside to check if it start when its in 'N' and it does start. Now I'm a little bit relieved. Thanx man
Old Nov 1, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I'll tell you exactly what it is... because we used to have one. Basically the contact goes bad or gets gunked up and it needs to be in that one sweetspot for the car to realize its in park. 2 things you can do... take the console apart (its easy, the trim around the radio and change tray pop off, then the bottom panel around the lighter/ash tray comes off then you can lift the shifter trim up (This is 3rd gen stuff, see maxima.org for full details). Then take a pencil eraser and clean the contacts. Easier solution, shake the shifter before you start the car. Neutral is also an option, but if it has the "Shift Lock" Feature, its a bit more of a PITA.
Old Nov 1, 2004
Thanx also. I kinda figured the shaking the shifter before starting. Each time before I start I kinda wobble the shifter back and forth and so far its been starting normally.
Old Nov 3, 2004
2K1Civic17"Gabe's Avatar
He is completely Right, dont have to shake it, just put it in park. every auto trans. comes with that feature.
Old Nov 8, 2004
PlasmaGT's Avatar
My Baby Daddy
PlasmaGT is on a distinguished road
These guys are right. The actual name of the faulty part is neutral safety switch. I actually had the same problem on an older Nissan. I had to hold the shifter forward and turn the key at the same time to start the car.
Old Nov 9, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
Nice Diagram!!!
Same thing on my Old Probe,
Don't stress it just bump it into park.
Old Nov 9, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
don't forget, as well as that being a saftey feature, if you stop your car, and don't put it into park and reach for your keys to take them out, they won't come out because it's still in gear. just an fyi
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
gabrown2
Apr 11, 2015 08:22 PM
CiViCPrAnInG2k1
Nov 1, 2001 03:47 PM
