Sway bars on HX
Old Nov 1, 2004
BlueHx's Avatar
BlueHx is an unknown quantity at this point
Sway bars on HX
Okay, I've been doing alot of searching on this site for info on stock HX swaybars. Basically i'm more confused now because one thread i read stated that the HX has no stock front sway. Well that sounds believable but my question is do i need the mounting kit for the front(don't think so but im not sure)
Last question, some places say the HX has no rear sway bar, but in another place i read that it has the 12mm, So basically just want to know whats up and if i need the mounting kit for the rear
thanks cause i plan on ordering the progress front/rear setup soon
Old Nov 1, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Well, the best way to check is to get under that car and take a look. The rear is easy enough to see - just drop to the ground and look under the rear bumper cover. The front, you'd likely have to jack up to check.
Old Nov 1, 2004
BlueHx's Avatar
Yeah that would probably be best but i was at work (workin hard ) when i posted the orignal. I checked the rear once i got home and don't really see a swaybar, but just to be sure would the rear sway bar be behind the rear control arm?
sorry noob here, and i've done alot of searches
Old Nov 1, 2004
robbclark1's Avatar
Retired suspension supermod.
http://www.sceniccityonline.com/arti...ybarspecs.html
Old Nov 1, 2004
BlueHx's Avatar
Thanks robbclark you da man!!
Old Nov 1, 2004
robbclark1's Avatar
Thank Bellz. It's his site.
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Viczhou
Sep 2, 2015 07:55 PM
