Sway bars on HX
Sway bars on HX
Okay, I've been doing alot of searching on this site for info on stock HX swaybars. Basically i'm more confused now because one thread i read stated that the HX has no stock front sway. Well that sounds believable but my question is do i need the mounting kit for the front(don't think so but im not sure)
Last question, some places say the HX has no rear sway bar, but in another place i read that it has the 12mm, So basically just want to know whats up and if i need the mounting kit for the rear
thanks cause i plan on ordering the progress front/rear setup soon
thanks cause i plan on ordering the progress front/rear setup soon Yes, it's an Acura EL
Well, the best way to check is to get under that car and take a look. The rear is easy enough to see - just drop to the ground and look under the rear bumper cover. The front, you'd likely have to jack up to check.
Yeah that would probably be best but i was at work (workin hard
) when i posted the orignal. I checked the rear once i got home and don't really see a swaybar, but just to be sure would the rear sway bar be behind the rear control arm?
sorry noob here, and i've done alot of searches
Raiool
Oct 1, 2015 10:42 AM
beanhead
Sep 24, 2015 12:04 PM
