12.5 @ 113 Mph
Old Oct 27, 2004
K20-6spd's Avatar
K20-6spd has a little shameless behaviour in the past
12.5 @ 113 Mph
Hey guys, this is my first post here, i have an RSX, but i also have an 03 civic coupe as my DD. I just wanted to share my quater mile time.
BTW: this time was only at 9 psi, i tried 16, but i broke an axle, so when i get the axles upgraded ill have a better time, i hope low 12's or maybe high 11's with slicks, but i doubt ill bust in the 11's. Thanks.
-HF
Name:	12 second time slip.jpg
Old Oct 27, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Old Oct 27, 2004
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Is that on stock internals?
What kinda of tires were you running at the track?
Old Oct 27, 2004
K20-6spd's Avatar
yes thats why i only run it at 9 psi right now, but after my pistons, and rods, and other ****, maybe forged crank. but i dont know, im going to run 14-16 psi daily, i was running BFG Drag radials. they stick, but not that hard. i want my upgraded axles and my slicks.
Old Oct 27, 2004
YSIDRAG's Avatar
Vary nice,Im getting all my stuff together to swap your motor in to my 01 civic and possably boost it to. Didn't no what it was capible of with stock internals. Thanks for the info.
Jay
Old Oct 27, 2004
icebergslim's Avatar
BOOSTED HYBRID
icebergslim is an unknown quantity at this point
With a trap of 113 you should be around 12.2 -12.4. Depending on your 60fts.
Old Oct 27, 2004
BOOSTED HYBRID
It says in your sig cybernation stage II. The stage II comes with pistons and rods.
Old Oct 27, 2004
Blainestang's Avatar
Blainestang has a spectacular aura aboutBlainestang has a spectacular aura aboutBlainestang has a spectacular aura about
Obviously they stick well enough to break your axle j/k Nice run. You are getting pretty good traction though for FWD. My friend's '03 Cobra trapped 113mph stock, too, but crossed the line with a 12.9 ET. Again, nice run and Good luck with future mods.
Old Oct 27, 2004
Spider883's Avatar
9K Redline Owns U
awesome run
Old Oct 27, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
I wouldn't sweat breaking into the 11s. That'll require running a cage, which is more weight and will slow you down again. If you go to slicks, upgrade your lug studs as well or you risk shearing them off. Slicks will also put more stress on your drive train. Mid 12s at 113 is damn good. Congrats
Old Oct 27, 2004
abmerop18's Avatar
Jam out with your clam out.
nice. very good 60 ft time
Old Oct 27, 2004
RSXtypeIvtec's Avatar
Su Mo
very nice
Old Oct 27, 2004
Wolfgang5884's Avatar
thats one fast rsx!!!
Old Oct 27, 2004
grindsman's Avatar
grindsman is an unknown quantity at this point
awesome times my friend. that's alot of boost for stock internals i thought. i'm still new to the turbo world but doesn't the k20a2 have high compression pistons which would be bad under high boost?
Old Oct 27, 2004
K20-6spd's Avatar
I know that, i didnt order it with them though, they will leave whatever you want out, and put some extra stuff in if you want. personally i had them leave out this"
-Piping under engine(theirs goes UNDER the subframe and some other problems with sealing right as my friend found out)
-Apexi S-AFC (I have K-Pro so theres no use for it)
-Piston and Rods (Im getting custom JE pistons and Crower Rods)
-and they also left off there Black Magaic II ELF (once again, i have K-Pro and can tune everything manually myself)
I had them add a Greddy BOV instead of their wierd one, give me a few rolls of that bad *** heat resistant tape for my piping, and make sure they gave me a 62-1 Turbo so i could boost higher than their usual T3/T4.
And there ya go
Old Oct 28, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
if i were female, i would want to have your babies
Old Oct 28, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
probably the gayest comment EVER
Old Oct 28, 2004
someguy's Avatar
someguy is an unknown quantity at this point
damn. and mad props to you.
Old Oct 28, 2004
SMX's Avatar
SMX
JE/Crower are quality products. Looks like you know your stuff.
Old Oct 28, 2004
K20-6spd's Avatar
Thanks Guys!
Old Oct 28, 2004
blkdak99rt's Avatar
Riceburners Bitch
blkdak99rt is an unknown quantity at this point
damn dude that ***** moving..... shame you broke an axle every fast fwd car does that though which is why i dont car for the fwd platform good luck with getting your new times
Old Oct 28, 2004
CivicsRdBest's Avatar
Wow... Nice work.
Old Nov 16, 2004
Mainstray's Avatar
Mainstray is an unknown quantity at this point
Nice!
Old Nov 18, 2004
xX03EXx's Avatar
Sweetest Dude on 7th Gen
I love how the rsx and even the tc come out after us yet have a plethora of part already. It's cool though, just makes me want to save up to get a faster car.
Props on your car tho man. I would love to see some pics of it.
mistahlorax13
21
Nov 18, 2015 12:47 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Munzy
21
Oct 7, 2015 07:48 AM
winanthony94
Sep 25, 2015 09:05 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
