Sponsored by:
Sponsored by: CARiD
What is a good silicone sealant to use on oil pan drain bolt?
Old Oct 24, 2004
streetglower's Avatar
No, not in the drain bolt, but on the outside to prevent leakage at the drain plug?
This might be my last resort to my leaking oil pan. I was told to use a silicone sealant around the drain plug to prevent the leaking of oil.
If you dont know, I recently threaded a bigger bolt in my oil pan because the old one stripped the pan, and it still leaks out of the drain bolt. I am trying everything so I dont have to replace the oil pan.
I need something that will hold strong enough and resist heat, yet come off each time I change my oil? Let me know.
I was thinking about using hondas sealant that they use for the oil pans, but using it around the drain plug, what do you think?
RIPSAW
Nov 6, 2015 04:36 AM
jmdcivic
May 20, 2015 09:52 PM
BootyDo
May 7, 2015 04:46 PM
pheaton
May 4, 2015 08:26 PM
leon1
Apr 28, 2015 07:32 PM
