Discharging Capacitor
Old Oct 23, 2004
fonto's Avatar
The LA Clipper
I need to take the cap out of my system. I did a search and I am too lazy to read through the 300+ capacitor threads.
I forgot how to dischage my cap, so can someone give me the run down on how to do it? thx
Old Oct 23, 2004
MegaHurtz's Avatar
I use a test light
Quick way is to turn your amp on to brig the voltage down quickly then test with a test light and/or multimeter to make sure it is all empty
Old Oct 23, 2004
fonto's Avatar
The LA Clipper
Originally Posted by MegaHurtz
I use a test light
I think i need a lil more instruction
Old Oct 23, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Unplug the cap from the charging system of your car. Then ground your test light to the neg terminal and touch the pos terminal til the light goes dim.
Old Oct 23, 2004
MegaHurtz's Avatar
yeah take out the fuse or manually trip your breaker and put the test light across the terminals on the cap
basically unplug the power from it and then put a load on it to drain the charge
Old Oct 23, 2004
Ed's Avatar
Ed
yeah, just connect a light bulb to the two terminals on the cap, or, just lick both sides at once.
Old Oct 23, 2004
takumi's Avatar
takumi is on a distinguished road
Easiest way is to touch the 2 terminals together with a piece of metal, it'll create a spark and be discharged. Wear rubber gloves
Old Oct 23, 2004
MegaHurtz's Avatar
Yeah you can do that too but it's a little frightening not to mention dangerous
Old Oct 23, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
wussies. i use my tongue
Old Oct 23, 2004
Ed's Avatar
Ed
wet your ***** and use that... ooh man :-/
Old Oct 24, 2004
jttegx's Avatar
OMNES AD UNUM
wtf
Old Oct 24, 2004
J187's Avatar
Probably easier for some people to find their test-light than to come across a pair of rubber gloves though
SO, you could use your *****, your tongue or rubber suit, OR you could just use the Friggin test light! LOL
If you are gonna use your tongue or your *****, I'd suggest making sure the coast is clear. If you are seen doing that, you'll never talk your way out of it
Old Oct 24, 2004
MegaHurtz's Avatar
Hey I've got like boxes upon boxes of rubber gloves sitting in my garage
Old Oct 24, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
You could always do it indoors while nobody's home........
oh man just thinking of an electrical shock.. ahh no.
Old Oct 24, 2004
MegaHurtz's Avatar
You could pee across the terminals as well
Old Oct 24, 2004
ohiojosh78's Avatar
Nope. Dont you watch Myth Busters. They tried to pee on an electrified rail and it wouldnt conduct electricity. The urine stream breaks up as it flows.
Sorry to burst your bubble but i'm just letting you know so you dont try it
Old Oct 24, 2004
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
Bridge the 2 leads with your tongue.
Old Oct 24, 2004
MegaHurtz's Avatar
I do watch that show but I didn't see that particular episode but I did see the jackass clip where one of those idiots get electrocuted by trying it.
Old Oct 25, 2004
ohiojosh78's Avatar
Really, how close were they? On M.B. they showed that a urine stream breakes up into seperate water droplets after 2-4"
Old Oct 25, 2004
MegaHurtz's Avatar
Maybe he got lucky?
mohawkboom
32
Oct 9, 2006 02:49 PM
nguyen949
Oct 2, 2003 02:26 AM
Civic2001LX
Apr 27, 2003 11:42 PM
alienmonkey
15
Apr 24, 2003 08:17 PM
noahnoah
24
Jul 21, 2002 06:47 AM
