Discharging Capacitor
The LA Clipper
I need to take the cap out of my system. I did a search and I am too lazy to read through the 300+ capacitor threads.
I forgot how to dischage my cap, so can someone give me the run down on how to do it? thx
I use a test light
Quick way is to turn your amp on to brig the voltage down quickly then test with a test light and/or multimeter to make sure it is all empty
The LA Clipper
Originally Posted by MegaHurtz
I use a test light
yeah take out the fuse or manually trip your breaker and put the test light across the terminals on the cap
basically unplug the power from it and then put a load on it to drain the charge
Originally Posted by Takumi
Easiest way is to touch the 2 terminals together with a piece of metal, it'll create a spark and be discharged. Wear rubber gloves
SO, you could use your *****, your tongue or rubber suit, OR you could just use the Friggin test light! LOL
If you are gonna use your tongue or your *****, I'd suggest making sure the coast is clear. If you are seen doing that, you'll never talk your way out of it
Originally Posted by J187
Probably easier for some people to find their test-light than to come across a pair of rubber gloves though
oh man just thinking of an electrical shock.. ahh no.
You could pee across the terminals as well
Sorry to burst your bubble but i'm just letting you know so you dont try it
Originally Posted by ohiojosh78
Nope. Dont you watch Myth Busters. They tried to pee on an electrified rail and it wouldnt conduct electricity. The urine stream breaks up as it flows.
alienmonkey
15
Apr 24, 2003 08:17 PM
noahnoah
24
Jul 21, 2002 06:47 AM
