Car Running Hot??
Old Oct 23, 2004
S2KREY's Avatar
formerly 2k1CivicRacer
S2KREY is on a distinguished road
Car Running Hot??
this has been happing lately, my temp gauge rises when my car is idaling (SP) it only does it after i drive for a while 15-30min+ when i start moving the temp drops back to normal. i change my coolent and my termistat (SP) and it still does it...so anyone know WTF is going on?
Old Oct 23, 2004
jttegx's Avatar
OMNES AD UNUM
is your radiator functioning correctly?
Old Oct 23, 2004
Civicster's Avatar
^what he said
Old Oct 23, 2004
DizWikedCivic's Avatar
flush the whole system with distilled water, idle the car, flush it again. add distill water, then flush again, change all your raidator hoses also, make sure your fan is working too, check all the fuses and fan switch, might wanna scope out your water pump too
Old Oct 23, 2004
civicguy777's Avatar
civicguy777 is on a distinguished road
and andrew comes through with all the answers again...
Old Oct 23, 2004
Civicster's Avatar
you car nerd
Old Oct 23, 2004
S2KREY's Avatar
k, both fans work, and fuse are koo, so how do i find out the water pump is ok?...and hoses are koo also...
Old Oct 24, 2004
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
When this happened to my truck, it was the water pump--all three times. I hope it's not your water pump.
Old Oct 25, 2004
flotsamm's Avatar
One way to see if its your water pump is to check if the top and bottom hoses feel different in temperature. The top one should be hotter then the bottom after the engine is warmed up and with the fans running. Get it warmed up, let it idle until the fans kick in and try to see if you can feel a temp difference between the hoses. Not sure how easy it is to reach them though, becareful. This is where a temp gun comes in handy.. good luck. If there's no temp difference, could be that your water pump is defective.
Old Oct 26, 2004
S2KREY's Avatar
yeh there is a diff. in the hoses and in the resorvor.... so how much is a water pump and is it hard to install?...
CarStuff
Dec 6, 2020 12:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
beneditti
Jan 15, 2016 12:31 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
