Sponsored by:
Sponsored by: CARiD
5w30 motor oil users
Old Oct 20, 2004
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
Hey
I'm thinking of switching from mobil1 5w20 syn. oil to royal purple's 5w30. And it's been a few years since our lil D17 came out, and I know that some of you use 5w30 instead of the owner's manual's recommended 5w20. I just wanted to know how your engine's running now, and if it was worth the switch. Also, what brand did you settle for?
Old Oct 20, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I've ran mobil 1 5w30 for 3 years with no problems, and just now switched to redline 5w20.
Old Oct 20, 2004
R1Style's Avatar
switch oil grades will void your warranty. Just thought I'd let you know.
Old Oct 20, 2004
iLLuMiNaTi's Avatar
the warranty on the whole engine?
Old Oct 20, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
It runs cooler and smoother with 5W-30 than with the **** oil they recommend from the factory.
BTW, 5W20 is a Recommendation, not a requirement, and it does not void your warranty... especially when some dealers aren't filling cars with it.
Old Oct 20, 2004
streetglower's Avatar
not everything, mostly internal ****. Dealers will take a sample of your oil and send it in to get it checked.
Old Oct 20, 2004
But I am running mobil 1 10w-30 because I am high mileage
Old Oct 20, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
A bunch of ppl on this site from So. Cal use 10W30. I have been using 5W30 ever since the 1st summer I had the car, and switch back to 5W20 in the winter.
Old Oct 20, 2004
Lakkaida's Avatar
Lakkaida is an unknown quantity at this point
ive been using the recomended Honda oil, which is better for the winter time? i got 50K miles on my ride.
Old Oct 20, 2004
jttegx's Avatar
OMNES AD UNUM
^im wondering the same thing. i've been using 5w30 since 5000miles and now im at 16k miles with NO probs at all. winter season is comming up and expecting cold wind and hard rain. good idea to start filling with 5w20? or would 5w30 run the same?
Old Oct 21, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
For the first 35,000 miles I used Castrol GTX 10w-30..
Now I use Mobil 1 10w-30.
Also, using a different motor oil, does not void your warrenty, that isn't even true with fords, which is more common of a rumor.
Old Oct 21, 2004
Running any oil is fine, so long as it is the correct grade of oil for the car. This is specified in the owners manual. Almost all new oils you can find on the shelf are fine for use, some however are better than others. Most new 5w20's outperform the older 5w30s and 10w30s in terms of TBN and other factors after extended oci.
I recommend reading on www.bobistheoilguy.com for further info.
Old Oct 21, 2004
kikoy's Avatar
kikoy has a little shameless behaviour in the past
its a multi viscosity oil.....the "5W" is only for the winter grade(@ o deg flowing) and the "30/20" is for the summer....
basically its good to run thinner oil in the winter to get to the normal oper. temp and also improves the gas milage or so i have been tought and on summer thicker oil is recommended since its hot and also thins/breaksdown the oil on high temps....
correct me if am wrong.....
Old Oct 21, 2004
ragingSPAM's Avatar
I just burnt my tongue
if u want good oil get AMSOIL 0w-30 100% synthetic high fuel efficiency formula...with that u can run the oil for 35,000 miles before you need to change oil as long as u change your amsoil oil filter 12,500 miles....it costs $9 a quart but it will save you money in the long run...i run amsoil synthetic in my civic and it actually helps on power gains, fuel efficiency and the engine is more quiet than it was when the car was new...dont have to change my oil for 35,000 miles...its freakin sweet ****
Old Oct 21, 2004
kikoy's Avatar
id still change my oil.......35k on no oil changes is a bit or rather say way too scary for me....one thing our motors need at least the API rating of at least "SJ" also the 0w-30 is a one weight oil...well at least 0 flowing at winter time but that will be like water.....
one thing am doing is sticking to a regular 5w-20 -10w-40
flame me but i don't want to change my engine anytime soon....
Old Oct 21, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
oil grade/weight doesnt have much to do with tbn and oci interval.. i dont know where you got that idea..
and by the way.. there is no such thing as mobil1 5w-20 syn..
Old Oct 21, 2004
iLLuMiNaTi's Avatar
hmm.. weird that's what is on that lil oil sticker thing on my windshield that the guys at the dealership put when they changed my oil.
Old Oct 21, 2004
BigGeorge's Avatar
BigGeorge is an unknown quantity at this point
Smile
I heard that gear oil will give you 100 extra horse power?
Old Oct 21, 2004
ynok20's Avatar
ynok20 is an unknown quantity at this point
ive never seen moblil 1 5w-20 syn only 0w-20syn
Old Oct 21, 2004
zen_master's Avatar
damn, been using 0W-20 for the last 3 oil changes..
i actually felt very nice difference on the third oil change...probalby since eveything cleared up down there (from the original dino oil)?
Old Oct 21, 2004
I'm not talking about the weight specifically, the GF grade that 5w20 specs as is higher than older 5w30/10w30.
Old Oct 21, 2004
civicfrenchie's Avatar
civicfrenchie is an unknown quantity at this point
Royal purple as above 11 viscosity at 100 deg C and most of 5w20 are between 8 and 9 at same temp...very good protection but a little bit thick IMO, because of our tight tolerence engine specs... it will hurt mpg and performance a bit...since we don't have a lot of power preserve your power and stay with 5w20...royal purple,red line if you want spend alot $$$ or castrol syntec(new 5w20) or mobil 1 0w20....for daily driving a good dino like pennzoil or castrol gtx 5w20 will do the job...
Old Oct 21, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
wouldnt you have to change it anyways in order to change the oil filter at every 12.5k??
Old Oct 21, 2004
iLLuMiNaTi's Avatar
well i'm one of those irresponsible, wreckless hoodlum teenage drivers, who drives his car pointlessly hard. think royal purple would be good?
Old Oct 21, 2004
yes but in 5w20
Old Oct 21, 2004
iLLuMiNaTi's Avatar
0h n03s everyone! we've got ourselves a hillarious person here on the forums!
Old Oct 21, 2004
iLLuMiNaTi's Avatar
yes but in 5w20
lol
k thanks a lot man.
Old Oct 21, 2004
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I've been running the Mobil 1 5w-30 for years now, I use it in the summer and our New England winters. I hear the Mobil 1 is a little thinner than what they say, so it's more like a 20. I've had good luck with it, the engine runs really smooth and I get the oil for $23 for a box of six.
Old Oct 21, 2004
you're right about mobil 1...it's a thin 30 weight...like a 5w25(i know it doesn't exist, but it's the best i can describe...)
pretty good oil...
Old Oct 21, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I've been running Mobil 1 0w20 in my car for about the last year. I've daily driven it, I've long distance cruised it, and I've autocrossed on it. No complaints at all (except it could be cheaper). My UOA's were tip-top. Believe what you want, because opinions about oil seem to be even more prevalent than @$$holes, but I refuse to believe Honda would recommend an oil just for the CAFE benefits (when they already have one of the most fuel efficient fleets on the lot).
