Squeek only when depressing brake
Old Oct 13, 2004
2K1Civic17"Gabe's Avatar
I have searched and searched, but found nothing. The search is becoming less helpful daily. But my problems are:
1-Brakes - When I let go of the brake, it make a squeek noise. It never makes it when I press the brake, or am driving, but every single time I let off the brake, it squeeks. Any ideas? Bleed brake lines, new pads. I probably am going to need new pads soon anyways.
2-Upper Mount - I have stock suspension, was never replaced (01civiclx). When I am driving slowly, and make a turn or go over a speed bump, I hear a loud A$$ popping, cracking noise. I have had my CV boot\joints checked,a nd they are fine. My mechanic told me new struts, but if I only need the upper mounts that would be better, since Im saving for a new suspension anyways, but I would like to fix this right now. I really dont believe my struts are blown, they arent very bouncy or anything. Any sugestions would be greatly appreciated.
Thank you, sorry I couldnt find my answers in the Search, or vehicles issues.
Old Oct 13, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
it might be master slave cylinder.. check it out
Old Oct 13, 2004
I know I just had my master cylinder replaced, is the slave different? That would suck to have to replace that too
Old Oct 13, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
slave cylinder is clutch related.
if u just had ur master cylinder replaced it might just be lack of lubrication somewhere. id get down there and push it to hear exactly where its comin from
Old Oct 31, 2004
dacivic's Avatar
dacivic is an unknown quantity at this point
I start to have the same problem. Did you find out where it was coming from?
Old Oct 31, 2004
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
check you calipers if you have leak, brake pads wont let go on rotors, might have problem on your pistons too. same on your reaR drums..
Old Nov 2, 2004
Im gonna find out either friday or monday. When I bring my car in for new suspension, ill have them check it out. They'll fix it for free anyways.
Old Nov 2, 2004
And its the right brake, By the way
Old Nov 2, 2004
speedcreations's Avatar
speedcreations is an unknown quantity at this point
mine does it too.....i think it's my drums...
Old Nov 8, 2004
dacivic's Avatar
anyone find out this problem yet?
Old Nov 14, 2004
ArtIntown11's Avatar
The Original F*ckin Angry Armenian
ArtIntown11 has a little shameless behaviour in the past
i had it before it was the drums, problem with the springs down there, i didnt solve it....just got a rear disc conversion instead.
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
tommycanada
Sep 5, 2015 04:59 PM
