Radio on during remote start
Well, currently when I remote start my car the deck does not work, which Is a good reason I suppose because most wouldn't want there system bumpin when there not there, but i tend to listen to a lot of music when im parked and sitting out side the car, especially up at the cottage, so that means I have to leave the keys in the ignition which makes me have to sit next to the drivers door the whole time. Or when I just leave the car running on remote start and run into the bank my firends still wnat to listen to music but dont let them because i never leave my keys unattended.
Long story short, how would I Make sure the deck is on when I remote start the car?
Hook your decks remote wire up directly to the battery. You'll just have to turn off your deck every time you turn off your car.
It wont start because your key isnt set to the accessory position, thus not giving the reciever remote any signal.
Unless you can find something that turns on when you start your engine whithout using the key. it doesnt draw much juice at all so if you can find anything at all just stick the wire in and see if it works
Don't Listen To What Anyone Says, It's Ok To Be Jealous
i hooked up my own remote start and when i did the radio turned on instead of the ac. depending on the alarm you have there is a wire for secondary ignition. since hondas dont have that you can hook it up to the radio wire. i think its the red and whit one in your ignitoin harness. if you hooked up your own you will know what i am talking about
im going to my audio shop today ill ask em about the second ignition feature
on my viper (dei) alarm i used the orange(accessory circuit) for the ac and i used the pink/white(output to second ignition circuit) for the radio. if they say they cant do it then tell them they're lieing.
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
loquito
Nov 12, 2001 07:24 PM
