LED connection, help
Old Oct 9, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
I am trying to do the VTEC light DIY yourself but I ran into a roadblock. I picked up an LED of 5V(highest that they had) and a 440Ohm resistor. I tried testing it and connected it like I think it should be, pictured here:
(sorry for it being so blurry, could not get my camera to focus on it)
Now when I try to connect it to to the car battery (the other end of the LED to ground of course), it doesn't light up. Any ideas?
Old Oct 9, 2004
Did you connect the power to the right lead on the LED? The LONGER lead on the LED is for power.
Old Oct 9, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
i cant see cause the picture is too big
Old Oct 9, 2004
ohh the resistor goes on the ground i thought
Old Oct 9, 2004
No, don't confuse him even more. Here is exactly how to connect it. Notice power goes from battery to resistor to long lead of LED, and finally to ground.
Old Oct 10, 2004
winnerpl's Avatar
Thanks gearbox for the pic. Big props.
But if the resistor does in fact go to the long end, then the DIY is is wrong (I think):
Time to set the LED up. You need to put the resistor in series with the ground lead of the LED (for those who don't speak electronics, you need to hook up one resistor lead to the shorter lead on the LED and the other end to the wire you grounded)
Well I tried to connect is all the wys possible and it still doesn't light up. Maybe the LED just doesn't work, I'll get another one tomorrow.(The fact that's it's a 5V one doesn't matter even if we use it in a car)?
Hmm I'm mad at myself that Ic an't figure this one out. I mean I connected my whole audio system myself (hu, 2 amps, comps, subs).
Old Oct 10, 2004
Well the forward voltage determines the resistor to be used. Mine were 4v, so I used 580 ohm resistor. If you burnt the led, you should've seen it light up really bright for a second and then fizzle out. Try another one. Maybe yours got ruined. But the pic above is how I wired mine.
Old Oct 12, 2004
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
all my led is blow 4v
i look for the highest mcd (brightness) the resister i use is 470ohms not 470k ohms
big difference
o i forgot to give u guys the link to where i find more info after i saw gearbox did it...mad props brotha
http://www.ledautomotive.com/
dont buy nething from the site,...just learn man..trust me i already bought 1
Old Oct 12, 2004
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
Prolly just a bad led. The setup looks fine electronically.You could have fried it with heat (fom a soldering iron) or from ESD which is unlikely.
JetsterDajet
52
May 8, 2016 12:11 AM
haloway13
Nov 6, 2015 10:43 AM
Jrosa
Sep 14, 2015 08:24 PM
shaejb15
Sep 12, 2015 01:02 AM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
