Best Swaps
Old Oct 8, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
Best Swaps
K24 with tranny. rumors around 2-3k
k20? type s rsx
k20? reg. rsx swap
which is good and easy?
Old Oct 8, 2004
someguy's Avatar
someguy is an unknown quantity at this point
dude you should specify which k24....cause they come outta different cars with different ratios. i got the numbers here...pm me if you want them.
Old Oct 8, 2004
cosmo's Avatar
cosmo is an unknown quantity at this point
Don't even bother with the K24A2 from a TSX. May have more power than a regular K24, but how are you going to get around the electronically controlled throttle body? Just buy a K24 block and bottom end, and slap on a head from a RSX Type-R or S.
Old Oct 8, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
you can just buy a k20 or k20a1/3/4 throttle body
out of all of those, I would go with a k20a2
Old Oct 9, 2004
cosmo's Avatar
Ya, if it was that easy would I have mentioned it?
Old Oct 9, 2004
obguam's Avatar
obguam is an unknown quantity at this point
Just read September issue of Honda Tuning; excellent in depth analysis of "new" K20 engines, advantages and disadvantages of various componants with lots of input from Hasport and Hondata. October issue has an article entitled "Hybrid How-To" which shows the ideal setup, a frankenstein: K20A2 (RSX Type S) head mated with a K24 (2.4 liter) short block from a CRV. I believe Hasport has already fit one in a 7thgenvic. If you need to know how much this ideal setup costs, you can't afford it. Seriously, though, these articles are must reading for anyone considering a K20 swap.
Old Oct 9, 2004
d17lpower03's Avatar
d17lpower03 is an unknown quantity at this point
i already got the rsx type r dropped in for me liek a month ago...and im happy with it...if ur going to go for the type s...might as well spend like 1 or 2 extra grand or wait a lil longer and save up....its worth it...220 hp at 8400 rpm...and rite now im doing a lil upgrades on my engine if i can find some...then after that...turbo that sh*t..i know some people say it wont be good doing that turboing a type r...but i know some guy in line pro that got a k20 type r in his 96 hatchback..and turbo dropped in...muhahaha...but just saying..its your decision =P =P =P
Old Oct 9, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
well, that's what hondaluver is doing ... correct me if I'm wrong
Old Oct 9, 2004
nindoo's Avatar
Why is my vagina bleeding?
Has anyone here of rebuilding up our d17's? Is it possible to bore the engine but better pistons, prt polish and change the valve springs. I don't know what I'm talking about but I remeber this dude with a Teg and he had his stock engine redone.
Old Oct 9, 2004
robbclark1's Avatar
Retired suspension supermod.
That is the NA route. I have thought about it, but it will cost more than a turbo set up and only get about 170 if you are lucky. I think it can be bored to at least a 1.9 maybe a 2.0. If you invested 8k in the engine you can get 200 out of it. Compression is the determining factor of if you want to turbo or NA.
Old Oct 9, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
If you were going to spend money on a turbo also why didnt you just get the Type-S then. Cheaper and it already has a lower compression ratio.
Old Oct 10, 2004
HondaLuver's Avatar
Its a celebration bitches!
whats with my name being named
Old Oct 10, 2004
cambo's Avatar
I wish I was asian
last i heard, hasport hasn't released engine mounts for the k24 into non-si (SiR in canada) civics.
Old Oct 11, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
The standard RSX motor has clearance issues with the intake manifold. The K20 out of the Civic SI fits fine. The RSX-S K also has no clearance issues. So the "Best Swap" would be a K20A2, because of the easy drop in and the availability of the mounts.
Old Oct 11, 2004
TurboDreamZ's Avatar
Super Member
TurboDreamZ is an unknown quantity at this point
k20 type R swap. best way to go.. alllll motor
Old Oct 11, 2004
shmik1's Avatar
never really thought of a swap as "easy" but if I had $ i'd pay to have all that done and it'd b really easy.. just expensive..
Old Oct 11, 2004
exclusive_vtec's Avatar
u must have a lot of money... give me some
Old Oct 13, 2004
import2nr's Avatar
awd pwnz j00
any of the swaps would be better than your D17, obviously, but none of them are going to be "easy"
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
