k24a
ohh thought you meant k24a lol my bad....
k24a!! it has more torque than the k20 and it can't fit in our engine bay though I believe. no ones made the mounts yet? so I have heard....
so negative on the fitment so far.
Don't Listen To What Anyone Says, It's Ok To Be Jealous
false awhile back someone had a k24 block with k20a2 head and 6spd tranny in our vics. turboed and everything. just like the b series motor, k series mounting points are the same
The K24 block is 3/4" taller than the K20 (accomodates the 101mm stroke vs 86). Supposedly using HAsports K20 mounts, it hits the hood. Never seen it done, so I dunno. You can fit a K24 right into the Si, that I've seen pictures of.
Also not sure what a K24A is. K24A1 is the CRV engine, K24A2 is the TSX motor... its throttle by wire, thats a big complication, and the K24A3 is the Accord engine.
And they're cheaper because there's more of them.
Theres talk that HAsport is working on a separate K24 kit so the engine clears the hood.
IMO, no they're not going to drop in the near future. The swap is now possible in any Civic all the way back to the EF chassis (1988+).
All those cheap cars + Increasing B series VTEC motor prices (the supply is now fixed), mean there's gonna be more demand for the K motors.
Its a celebration bitches!
you can put the tsx k24 in, you just need to get a si, type S or R tranny because the tsx or crv tranny will not fit. with the TBW, just get another TB. with a wire system.. and change your ecu with kpro... other than that it should fit
