amplifier wire run ???????
Old Oct 4, 2004
holowach's Avatar
holowach is an unknown quantity at this point
where through the firewall can i run my 8 ga. wire from the battery to the trunk..... are there any empty grommets that will work ? or is there a grommet with wires going through already that i use? or do i have to drill a new hole? my car is a 2002 acura EL.... same thing as a civic pretty much.
Old Oct 4, 2004
MegaHurtz's Avatar
Well in the Civics we run the amp power wire thru the cluster of wires under the dash on the passenger side on the left side of the footwell. It's an existing grommet but it's a snap to run another wire thru.
Old Oct 5, 2004
WhiteRabbit's Avatar
I like the clutch hole on the drivers side, too. works pretty well.
Old Oct 5, 2004
4Saris's Avatar
4Saris is an unknown quantity at this point
I put two 8 ga in the cluster that Mega mentions. Just don't use a hanger or other ghetto tricks, you might cut or splice an important wire. Be patient.
jackoncruzpr
May 24, 2015 12:24 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Dmitri
123
Oct 13, 2005 08:01 PM
xHoteKx
Jan 8, 2002 09:15 PM
mikalem
Jan 5, 2002 10:21 AM
