k20a swap w/ turbo
Old Oct 1, 2004
es2's Avatar
es2
bubble party!!!
es2 can only hope to improve
k20a swap w/ turbo
i just wanting to know if anyone who has a k20a swap on their car knows if there is enough room to put a turbo also or if its even worth it
Old Oct 1, 2004
ImportRacer2123's Avatar
K20 Member
yes there is room for a turbo but with an RSX-Type R K20A why not go All motor?
Old Oct 1, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
not worth the extra money for a turbo itr motor ... 2 main reasons...
gearing is shorter - bad for turbo
high compression - bad for turbo
Old Oct 1, 2004
deciuss's Avatar
Boosted Auto
if you have the cash why not? i have seen some vids of turboed rsx's beating bmw's.
i think it was the k20a2 thow (rsx type s) ?
Old Oct 1, 2004
K20 Member
now NA Toda Engine Kit, LSD, Toda Header, Toda Flywheel, Injen CAI or AEM CAI and your at a mid 13 to low 13 second car
Old Oct 1, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^^ sounds like low 13's to me with some luck
Old Oct 1, 2004
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
a kid where I work has an overbored k20a boosted @ 18psi...I helped him with all the work
the biatch pulls like a mother through all the gears, I think he's taken it down into the 13's...but the kid has money, changed EVERYTHING up including internals etc. etc. etc.
if you have the money it certainly will fit depending on your turbo kit...fabrication needed...if you don't have room just blister the hood...
Old Oct 1, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
haha 13's? ... he must not know how to drive ... ;P
Old Oct 1, 2004
deciuss's Avatar
Boosted Auto
13's with all that modification? we have vics getting into the high 12's now with the d17
Old Oct 1, 2004
I said i think...he goes to englishtown a lot, the last time I can remember him telling me was a 13.1 or something a couple months ago
Old Oct 1, 2004
K20 Member
i would rather go all motor and spend the money on ITB
Old Oct 1, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
You better have some serious work done to the motor before you do ITBs.
Old Oct 2, 2004
allmotor's Avatar
nor cal 7thgens
go n/a
Old Oct 3, 2004
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
My civic has a K20A3 with greddy turbo and it all fit like a golve. I was worried abouth the clearance between the firewall and the turbo, but there is acutually more room there than you think.
Old Oct 3, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
what ur 1/4 at???
Old Oct 3, 2004
exturbo6's Avatar
if i had the money i would get a k20 swap and turbo that...theres a kid around in my area that has one and its fast as *****..so its def worth it without a doubt
Old Oct 3, 2004
Music1st11's Avatar
Music1st11 is an unknown quantity at this point
most definitely worth it rsxs are dipping into the 12's with under 10 psi. I've never run mine at the strip, but i'm sure I'm close, running 8psi/283whp. WORTH IT? I THINK SO!!
Old Oct 10, 2004
es2's Avatar
es2
bubble party!!!
thanks after hearing everyones input I think i am going to go with all engine until i get so more cash
Old Oct 11, 2004
someguy's Avatar
someguy is an unknown quantity at this point
good choice. i have a friend with an RSX with intake, exhaust and a hondata and runs 13's.
Old Oct 11, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Thats nothing my little D17 made 250whp on stock internals. I made 150% more power than the base dyno stock. You are makeing maybe 50% more.
Just busting your chops. Swaps arent everything. The mighty D17 can smake a little power to. Just there is a wall you will hit around 300whp. It is called a tranny. No one has upgraded that yet to find out if there is a replacement that will take higher numbers.
Old Oct 11, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
If you cant go mid 13's in this on 7-8 psi, then something is wrong.
The gearing is great for a 1/4 mile run. And as for compression, let me put it this way... The celica GTS is 12.5:1 compression. We run 8-10 psi all day long on pump gas and no alcohol with no problems. We ran 11 psi on the K20A2 with no signs of detonation.
Old Oct 11, 2004
00celicagts6spd's Avatar
^^ hehe 11.5:1 compression actually. but yeah will hold 10 psi np 10 psi on the SF gts kit dynoed 277 whp on stock internals and no boost controller. coulda made more power if we coulda held the boost steady lol
if you want to turbo the swap I'd say go for it. you'd have potential for a 12 second civic. (will be driver limited)
Old Oct 11, 2004
icebergslim's Avatar
BOOSTED HYBRID
icebergslim is an unknown quantity at this point
Catalyst, Did you guys already finish the tubo kit for the k20? Id like to see pics of the turbo manifold , if its possible.
Old Oct 12, 2004
k20importtuner's Avatar
k20importtuner is an unknown quantity at this point
k20a2 is best for FI.
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
justcruzin125
Aug 11, 2015 09:09 PM
JImmY1982MinG
South
Feb 9, 2003 09:53 PM
StLVtec
Oct 7, 2002 11:06 AM
lilbluecivic
Mid Atlantic
Feb 24, 2002 10:06 AM
