Any advice for exhaust?
Old Sep 20, 2004
03civda's Avatar
03civda is an unknown quantity at this point
Hello everyone. I just ordered a Greddy Evo 2 for an 03 EX sedan. I'm going to put it on as soon as I get it. Is there anything I should know before attempting to put this on. Any unusual obstacles or problems anyone has come across before? Thanks!!!
Old Sep 20, 2004
Get some pb blaster spray cause the bolts are gonna be really tough to get out. Might not even be able to do itunless you're really buff
Old Sep 21, 2004
jgoodfella1's Avatar
jgoodfella1 is an unknown quantity at this point
^^^^ Yeah.. I always have my friend tighten my bolts cuz I'm notorious for breaking bolts and stripping threads. When I installed my header I broke both bolts that mount to the down pipe. Good thing honda had em in stock. I like the evo2. Not too loud for an aftermarket exhaust. Installation is pretty straight forward.
Old Sep 21, 2004
civic2nr819's Avatar
civic2nr819 is an unknown quantity at this point
It shouldn't be to bad. I did mine with no problem and I have never touched an exhaust before. I would get something (liquid wrench) to spray the bolts.
Old Sep 21, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
If you want to do it right, chase all old threads with a tap and die set and use a torque wrench. That'll keep you from snapping bolts.
Old Sep 21, 2004
03civda's Avatar
So just make sure I spray all the bolts first. How long should I let the spray sit? Do you guys recommend using an impact wrench or can you do it all by hand as long as you torque the bolts right?
Old Sep 21, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
use schaffers penetro 90 on the bolts. best stuff on the market.
Old Sep 21, 2004
IDQcivic's Avatar
IDQcivic should not be trusted
I got an impact wrench at walmart for 20 bucks that plugs in the cigarette lighter and get a universal elbow joint so you can work at an angle, surprisinly it works very well to get rusted bolts off!
Old Sep 21, 2004
specter542's Avatar
I'm NeonImpact's a55hat!
specter542 should not be trustedspecter542 should not be trustedspecter542 should not be trustedspecter542 should not be trusted
righty tighty lefty loosey.
Old Sep 21, 2004
I'ts kinda one of those projects where you sparay your penetrating lubricant of choice on the bolts and let it do it's stuff for a few minutes. Then just get under there and do what you have to do to get the bolts loose. slam your nuckles a few times, hit your head and then fu,k around with those rubber hangers and your done. Then when you start your car you get to smell that new exhaust parts "burning smell"...MMMM. Then your stoked with your exhaust till it rains and makes some "weird noise". Drive home in the rain and post your problem in the tech forum without searching first
Old Sep 21, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
the bolts should come off ok cuz its only a 03
Old Sep 22, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
you might need to remove your heatshield from underneath your car, since the aftermarket exhaust is bigger in diameter then the stock one it might hit your heatsheild near your cat-converter. all you need to do to remove that is unscrew the 3 bolts holding it on. i had to do that for my dc tcs2
Injen
silverbullet09
Aug 27, 2015 02:18 AM
bhollie
Aug 12, 2015 09:58 PM
Kcpowerhouse
Aug 1, 2015 06:55 AM
JKWood
Jul 28, 2015 03:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
