Pinout For 14 Pin Connector On Stock HU
Old Sep 19, 2004
Arlof's Avatar
Arlof is an unknown quantity at this point
I'm looking for someone with a Helm's manual that would possibly have the pin out's for the stock headunit cd changer input. I believe it's 14 pins.
Regards,
David
Old Sep 19, 2004
Got Boost???'s Avatar
I believe this is it
1 - Yellow/Green - Antenna Modeule (coupe only)
2 - Yellow/Red - ACC (Main stero power supply)
3 - NOT USED
4 - NOY USED
5 - Pink - Right rear speaker (+)
6 - Blue/White - Left rear speaker (+)
7 - Green/Yellow - Passenger door speaker (+), right tweeter (+) couple only
8 - Green/Black - Drivers door speaker (+), left tweeter (+) coupe only
9 - Red/Black - Lights-on signal
10 - White/Red - Constant power
11 - NOT USED
12 - NOT USED
13 - NOT USED
14 - NOT USED
15 - Blue/Yellow - Right Rear speaker (-)
16 - Blue Black - Left Rear speaker (-)
17 - Grey/Red - Passenger door speaker (-), right tweeter (-) couple only
18 - Light Green - Drivers door speaker (-), left tweeter (-) coupe only
19 - Red - Dash Lights Brightness controller
20 - Black - Ground (G503)
this is from the honda service manual
Old Sep 19, 2004
heres a more colorful picture
Old Sep 20, 2004
Arlof's Avatar
Hrm Thats not it the one I'm looking for...
It's 14 pins and it's the CD Changer Input into the head unit. I believe what you have listed here is the head unit's main connector. But I might be wrong can you just confirm that thats infact the CD Changer Pin Out Boost?
Thanks for your time.
Old Sep 20, 2004
yeah i thats the main head unit.
But by CD changer do you mean an extrenal one?
Old Sep 20, 2004
Ok I know what your talkins about now. However its not covered in the Honda service manual (odd considering its 3 inches thick)
But Im gonna keep searching this for ya
Old Sep 20, 2004
Arlof's Avatar
Well, I haven't had much luck so, I hope you have better luck. I've found it listed as a bus cable on the installation instructions for the cd-changer.
Old Apr 28, 2005
P64's Avatar
P64
P64 is an unknown quantity at this point
This is the board of an european Pioneer-made HU. Everything is marked on it. So if you believe that yours is different, take it appart and compare.
1 BU
2 SWDACC
3 GND
4 SGND
5 RP
6 LP
7 BU
8 ILM
9 BUSP
10 BUSM
11 GND
12 NC
13 RM
14 LM
Oh by the way, how do I enable the AUX function? I want to connect an Ipod.
Have a nice day.
ID:	52727   Click image for larger version
Old Nov 27, 2006
adrianpglover's Avatar
adrianpglover is an unknown quantity at this point
I'm wondering if you were able to get this to work or not. I'm about to order the cable required and try testing some things out myself. I suspect you have to jumper either pins 1 and 7, 9 and 10, or 2 and 4. I have a strong suspicition that it is one of the first two combinations. If i get anything I'll let you know sometime next week.
Old Nov 27, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
The following info is from an 05 Accord but I think it'll be pretty close.
01 - 12V constant
02 - accessory
03 - ground
04 - ground
05 - Right Channel (+)
06 - Left Channel (+)
07 - 12V constant
08 - illumination (+)
09 - BUS (+)
10 - BUS (-)
11 - ground
12 - illumination (-)
13 - Right Channel (-)
14 - Left Channel (-)
Have fun...
Old Apr 22, 2009
nemiath's Avatar
nemiath is an unknown quantity at this point
Re: Pinout For 14 Pin Connector On Stock HU
Any luck activating the aux in ? Any tips you can provide since i been trying to do the same thing for my civic?
Old Apr 22, 2009
mdawg's Avatar
mdawg is on a distinguished road
I'm gonna bump this too, untill I get my carpc back into this car I need some aux in haha.
Old Jun 12, 2009
bmnot's Avatar
bmnot will become famous soon enough
BUMP
So I would totally rather wire up my own 1/4" jack as aux instead of buying an aux unit.
Does anyone have confirmed details on what to jumper and what to wire into for the audio?
(7th gen 2005 civic btw)
edit:
similar to what this guy did on his mazda: http://www.geocities.com/blhobbs.rm/...o_details.html
Misfit2613
Jul 30, 2015 09:49 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
