93 Octane my car loves
So I'm at the gas station deciding which gas I should get...So far I ran on the 87 gas, so tonite I was like **** it...I'm gonna go with 93, so I drive on that for like 10 miles and than I gota get up at six am to stock beer so I hop in my civic and it's really cold...I got AEM CAI and Custom Exhaust on it so far, man the improvement was major on that 93 octane, like I could feel the engine just push n push, anyone try this?
I wish I was asian
its just gas.
The difference in octane shouldn't cause a difference in power production unless your car is detonating or pinging.
Do you even know what the different octane ratings mean and what they do?
I like you! do you like me?
i have always been using 93, even 94 at times. 87 sucks ***. my dad used to use 93 in his MDX and now he uses 87 because of gas prices. it sucks ***.
our engines are designed for 86/87 octane. putting a higher octane in them won't change anything unless you have forced induction. it might actually be worse for the car. i met a guy who is a chemical engineer for exxon today and he just went over all of this with me. i used to put 89 in my car but not anymore. he told me that in the long run, it will actually hurt my engine.
I don't think it can hurt the engine. I've been putting 91 in my car since last year. BTW, I went to Europe this year, and I saw a couple 7th gen sedans...some woman was actually putting OMV super 100 in her car...I was like ****...
I mean all they have is 95 98 and 100, I don't think putting 91 in our cars will damage anything.
Originally Posted by gearbox
It could cause more deposits. I tried 93 a while back and felt like I lost power. So now I use 89. When my car was stock, I used 87.
doesn't like higher octane burn at a higher temperature? isn't that why it's pointless unless you'r running FI?
besides, our ECU doesn't have advanced timing to detect it why bother...
The higher octane rating is more stable if you're running FI or High Compression . . . it's totally unnecessary for our cars and you are probably hurting the car in the long run using it since it's been tuned for 89 octane. And that 95, 95, 100 is because they use a different system for rating the amount of octane in their gasoline. It could be slightly higher than gas around here, but they're using a different system to rate their gasoline
In europe we are putting 98 and 95 octane in cars.
It will not hurt you engine. It just burns better. You get more energy from it.
We buy always race gas, it cost like 250€/50l, and then you fill diference.
It's like a new car. Quick response.
Greetz
Greetz
You won't be hurting the engine, but it does nothing for power.
Higher octane fuel just burns more slowly thus your will have to retard or advance the ignition timing to achieve the power you would have gotten if you just filled with 87.
So have fun wasting more money on fuel and gaining nothing in return.
i use 89, only mod is hi flow cat. i used to use 87 regular when it was completely stock, but after the hi flow cat, i thought it deserved a little more =)
im not saying their was a better difference, just thought it'd be healthier for the car somewhat.
question... does gasoline become affected by weather and heat? example: using 89 plus in my civic would be better than 87 regular during hot *** days. or am i just an idiot?
So our cars are designed for the 89? and also to everyone the rating system is based on what percentage of fuels actually burns and what goes out as air...thus 93 would be 93% would burn and 7% would be a waste...The reason it could be a negative aspect on the engine is the fact that it causes a stronger explosion in the cylinder causing it to jump up harder thus giving you more power so STFU and spit knowledge
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel.
87 octane gasoline is gasoline that contains 87-percent octane and 13-percent heptane (or some other combination of fuels that has the same performance of the 87/13 combination of octane/heptane). It spontaneously ignites at a given compression level, and can only be used in engines that do not exceed that compression ratio.
So why don't YOU stfu and spit some knowledge?
I wish I was asian
Originally Posted by Mystic3030
What about 110 octace race gas? The engine is burning gas that doesnt exist?
I would say anything higher then 89 octane is a waste of money for a stock d17. There is no power gain in using higher octane gasoline with this engine plus it was designed for lower octane 87.
I think the higher octane improves gas mileages, last tank of gas I got like 35 MPG and I bought some expensive Shell gas which I never buy... Anyways I have my cam gear advanced 2 degrees and I have a venom-400 so I use high octane, it just seems my car bogs down more when I use the cheap stuff....
e-married to daydreamer
I've used 87 at times.
Now since I don't take my car out as much... I'd rather use a higher octane fuel so that I wont have problems with the fuel aging and etc etc etc.
Why is my vagina bleeding?
Other factors also affect the octane that should be used, like atmospheric elevation, temp, and a few others.
I use the 93 octane when I've used the odbII code reader
^keeping track of gas mileage varys though. weather conditions, what kind of roads, traffic hour, freeway, hard driving, etc etc. im pretty sure you dont make the exact moves on every other tank..
i had that "bog down" feeling too when i went from 91 to 89. i guess it was just my mind playing games on me.
this is an important question, hope someone can answer me: "will using 91+ pump gasoline harm our d17's (non f/i) in anyway?" how? (thanks)
I already tried that. Went on a trip with 89 and got 38mpg all highway. Then filled up with 93, drove it down, put in another tank, and went on the same trip. Mpg was about the same, actually a little lower.
You guys will, laugh, but I felt that the engine performed worse with 93. I put in 89 again and the car feels better. Someone else also reported that the ecu will adjust ignition timing with higher octane, and that's how performance is affected.
