Overboost protection...
El Pinche Turbo Mexicano
I know this has been discused and wanted to know if this Pop Off Valve would work?? , and would i need to do for it to work, like how to get a second presure source that does not see boost, and would it need a different flange than the one on the stock blow off valve from an SF kit..........
laught it up *** hole, it says it a blow off valve but can also be used as a pop off valve that open completely if it reaches a certaing psi and can only be closed manualy,
just wanted to know how to get a presure source that does not see vaccum..
I think that Greddy makes a tru pop-off valve, that doesn't rely on vacuum. It's a preset setup where once it hits a certain psi... it opens and vents. DO NOT use this as a boost controller though, it's only meant for spikes.
Do you know where i could get a pressure source that doesnt see vaccum, and i have a boost controller, i just want the added protection in case of a spike.........
weel i just got a new motor, ad dont want to blow it again, the problem is i have no way of knowing what failed,
a) the boost controller solenoid
b) faulty wastegate
c) common spike
what can i do to discard "a" and "b"
b) faulty wastegate
c) common spike
Originally Posted by familycar
you check the discription it is a blow of valve often known as a pop of vavle
CivicVTec
Feb 7, 2002 08:12 AM
