Overboost protection...
Old Sep 16, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
I know this has been discused and wanted to know if this Pop Off Valve would work?? , and would i need to do for it to work, like how to get a second presure source that does not see boost, and would it need a different flange than the one on the stock blow off valve from an SF kit..........
Old Sep 16, 2004
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
That is a blow of valve.
Old Sep 16, 2004
check the description....
Old Sep 16, 2004
familycar's Avatar
you check the discription it is a blow of valve often known as a pop of vavle
Old Sep 16, 2004
gotti's Avatar
roflmfao x 23423
Old Sep 16, 2004
laught it up *** hole, it says it a blow off valve but can also be used as a pop off valve that open completely if it reaches a certaing psi and can only be closed manualy,
just wanted to know how to get a presure source that does not see vaccum..
Old Sep 17, 2004
MadWheel's Avatar
Premium Boosted Member
I think that Greddy makes a tru pop-off valve, that doesn't rely on vacuum. It's a preset setup where once it hits a certain psi... it opens and vents. DO NOT use this as a boost controller though, it's only meant for spikes.
Old Sep 17, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
yea. a blow off valve and pop off valve are different things.
Old Sep 17, 2004
Do you know where i could get a pressure source that doesnt see vaccum, and i have a boost controller, i just want the added protection in case of a spike.........
Old Sep 17, 2004
Jaykuai's Avatar
ish...
TOO LATE..
Old Sep 17, 2004
weel i just got a new motor, ad dont want to blow it again, the problem is i have no way of knowing what failed,
a) the boost controller solenoid
b) faulty wastegate
c) common spike
what can i do to discard "a" and "b"
Old Sep 18, 2004
streetglower's Avatar
you need to check the description man, I have never heard of a blow of valve. It is Blow OFF Valve
boosted.es2
Engine Swaps
16
May 4, 2007 07:42 PM
Decamo
Engine Swaps
19
Aug 13, 2004 12:35 PM
TwilightX
North East
May 22, 2002 04:00 PM
CivicVTec
Feb 7, 2002 08:12 AM
