Cheapest way to get 200hp
Old Aug 30, 2004
pagefault's Avatar
pagefault is an unknown quantity at this point
What is the cheapest way to get 200hp? k20a swap? Can a stock d17 motor /w turbo get 200+ hp? To get 200hp on a d17 what engine mods are need, gasket? Thanks.
Old Aug 30, 2004
civic01vtec's Avatar
turbo will be cheaper to get you to your goal of 200whp
but..............
being cheap on a turbo set-up will result in u buying a new block and pistons
Old Aug 30, 2004
pagefault's Avatar
ok, asuming i get a nice turbo+intercooler+oil cooler, what mods to the engine would be best to take full advantage of the turbo READ: 7+ PSI. And this is a daily driver.
Old Aug 30, 2004
synapse missing link, boost gauge, a/f gauge, egt gauge, oil pressure gauge, full custom exhaust, clutch, piggy back fuel computer (safc or emanage) and the most important thing is the fuel system.
Old Aug 30, 2004
pagefault's Avatar
Why is fuel so important? I dont have to worie about head gasket breaking or the bottom end?
BTW thanks for all you help.
Old Aug 30, 2004
b/c u are adding air, you need the extra fuel to burn properly and avoid detonation which can result in buring a hole in ur piston.
Avoid detonation at 7psi and you HG will be fine. Turn it up to 10 psi and u will have problems.
Old Aug 30, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
turbo plus no fuel=destruction
turbo plus fuel= a smile on you're face
fuel is needed to offset the compression of the turbo. I suck at explaning things so ill let someone else jump on this one! There is ALOT of info on the site, so look around...
Old Aug 30, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
wats the EGT guage?
Old Aug 30, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Exhaust Gas Temperature
Old Aug 30, 2004
abmerop18's Avatar
Jam out with your clam out.
any readon you would really need this? cant really run 4 gauges
Old Aug 31, 2004
higher than normal exhaust temps usually mean that you are running lean............and u can run 20 gauges if you wanted to
Old Aug 31, 2004
Wolfgang5884's Avatar
How much would that beTo get our engines to 200whp that is.
Old Aug 31, 2004
It would take about $5,000
also with turbo on d17............u are also gonna have around 200ft/lbs of tq........which is where it's at
Old Sep 1, 2004
abmerop18's Avatar
not that much. ill be doing it for around 3500 if it all goes to plan
Old Sep 1, 2004
Old Sep 1, 2004
prototype's Avatar
x-factor
prolly a port and polish head, custom made intake manifold, intake header exhaust and a 75 shot of the juice
Old Sep 1, 2004
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
If you are planning on 200+ hp turbo Id say expect close to or over 5k if you do it right. If you scrounge and bargain maybe as low as 3500 with a LOT of extra time making stuff and friggin around. With the clutch, flywheel, intake mani., polished head, ss valves, springs and retainers, blockguard, headgasket, complete fuel sys converted to return with 440 injectors, full 2.5 exhaust, DS mbc, all the emanage goodies, heat wrap, alcohol injection, intercooler sprayer and all the other possible good stuff you can get with a dyno tune figured in, im in deep at about $9k+ but should be extremely reliable and realy goddamn fast. Should be back together within 2 months. Next year hopefully I will be sleeving, rods and pistons.LOL yeah it all depends on how far you want to take it. Im not stopping at least till I see 12s outta the FP civic. Just think, I dont even have 20k miles on the clock Bwahahahaha Whats wrong with me????
Old Sep 1, 2004
buy a new car
Old Sep 2, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
$5,000 to have 200whp on D17....I dont think so...I wonder what I have now....how much horsepower is 10psi....I know its different on different cars but I'm sure 9-10psi is CLOSE to 200whp right? someone enlightened me
Old Sep 2, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
10psi is like 220hp but like 200ft/lb of torque w00t
Old Sep 2, 2004
02fpcivic's Avatar
Ill be running 12pounds high, 6 low for every day driving. But that will be max till the bottom end is done. I figure hopefully 230 whp. We will see. Buy A wet kit if you dont need constant HP its WAY cheaper. I just like having power there all the time.
Old Sep 2, 2004
why not?
guns was dyno'ed at 230whp with a tuned vafc, ehaust and clutch...........that is about $5,000.
Old Sep 3, 2004
JetBlu01's Avatar
New Member
why not?
hmmm...I need to figure up how much I've spent so far....not $5000 though...maybe $4grand but thats pushing it
hondacivic0253
Sep 29, 2015 08:06 AM
greentoaster
Sep 1, 2015 12:18 AM
Wolfcamp
Aug 14, 2015 08:52 PM
muttleytm
Jul 14, 2015 05:31 PM
TaiChi
Dec 17, 2001 09:09 PM
