Bad Tein SS bushing, WTF! (w/pic)
Old Aug 29, 2004
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
I'm buying a new car in a few months, so this weekend was my weekend to remove my Tein SS, and replace it with my OEM suspension. it didn't go so well...
as you can see in the picture the bushing on my Tein SS is all screwed uP! somehow the bolt siezed to the bushing so when i was unscrewing the bolt it started twisting the bushing all out of shape. i sprayed the whole area with wd-40 but still no luck, the bushing just spins with the bolt!. i was afraid to unscrew it past the welded on nut to the right fearing i'd never get it back in, making my car undriveable. so I'm taking my car to the shop on tuesday asuming the bolt might need to be cut off. nevertheless the bushing is trashed and I'll probably have to send the shock to tein for a new one to get put in.
comments, suggestions..
Old Aug 29, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
wow that is wierd, has the car been driven through winter?
Old Aug 29, 2004
yeah they have one winter on them, they've been on my car for a little less than a year. the other side came off fine though.
Old Aug 29, 2004
robbclark1's Avatar
Retired suspension supermod.
eh, **** happens to rubber. That is why poly is suggested. Did you take the top mount off first or are you trying to get off the bottom first?
Old Aug 29, 2004
that was the last bolt i had to remove all the other bolts & nuts we're loose. and honestly when my friend & I put the Teins on we greased up all those exterior bolts & nuts.. besides not like i had a choice on poly, tein ships them with rubbers. and would that make a difference anyhow because isn't the center of those bushings metal?..
either way it annoys me
Old Aug 30, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
Yes, the center of it is metal. It has to be.
I was told to prevent that from happening during install (for B+G S3 full coilovers), you tighten that bolt once the car is on the ground.
Some inlets like that seem to be made better. I believe B+Gs uses rubber. Hayame uses poly.
Old Aug 30, 2004
7thGENDMAN's Avatar
7thGENDMAN is on a distinguished road
Thats the same thing that happened to my stock shock and I had to have the shop cut it out. Totally fried the bushing and lower half of the shock. Sorry bro, I know how you feel!!!
Old Aug 31, 2004
what kind of damage was done to the shock?.. i mean, i know the Bushing is trash. but I was hoping that i could just have a new Bushing pressed into the shock and be on my way..
Old Aug 31, 2004
arghh just got off the phone with the Mechanic, says he needs to cut the shock to get it out. so now I'll have a set of Tein's minus one rear shock. I called Tein to find out how much it would cost to replace it, they told me $230. this sucks!
Old Aug 31, 2004
7thGENDMAN's Avatar
yup, same thing mine had to do. See if he can just burn the rubber away and then he should be able to grab the metal inner bushing and hopefully get it apart. Sorry again.
cukaracha
30
Jul 26, 2015 12:01 PM
Bounddyy
Jul 8, 2015 11:22 AM
fatih717171
Jul 8, 2015 12:14 AM
cgavin1
Jul 7, 2015 07:10 AM
robbie374
Jul 7, 2015 02:56 AM
