Need help diagnosing sound
Old Aug 29, 2004
Storm897's Avatar
Storm897 is an unknown quantity at this point
I have a 2001 Manual Honda Civic Ex. It has 64k miles on it. It works like a charm. Never had a problem with it. All of a sudden about 5k miles ago I start hearing this sound. It only happens when the car is in gear and in the RPM range 3,500 through 3,800. It sounds like a rattling noise. When I rev my engine through that range and I am not in gear I dont hear the rattling noise. It only happens when I am in gear. It happens in all gears also. It is more noticible when I slow down (by braking, not using the engine and gears) and the car is still in gear. I am not sure what it is. What could it be? If you need more information I will be happy to provide it for you guys.
Thanks again in advance,
Oren
Old Aug 29, 2004
i got that crap too.. is it sound like its coming from under the dash? i dont know what it is but i'm about ready to rip my dash off and secure everything that has potential movement...
Old Aug 29, 2004
Well mine was actually a rattle coming from the engine. I swapped the cylinder head and it went away, but you could also try using 89 instead of 87 gas and changing the plugs. Also try some greased lightning brand fuel system treatment.
Old Aug 29, 2004
Storm897's Avatar
I will drive it around today and try to pinpoint the exact area where I think the sound is coming from.
The wierd thing is:
1.) It ONLY happens while I am in gear. If I rev my engine while parked though that RPM range nothing is heard.
2.) Sound ONLY happns in that RPM range. No other range.
Thanks,
Oren
Old Aug 29, 2004
Storm897's Avatar
I already tried Penzoil and Lucas Fuel System Cleaners any they didnt work. I am also trying an Auto-RX cleaning but that doesnt seem to help either.
Thanks,
Oren
Old Aug 29, 2004
Storm897's Avatar
Checked the spark plugs and they look perfect. They were also gaped correctly when I checked them. Additionally , I removed my header heatshield and the sound still occured.
Thanks,
Oren
Old Aug 29, 2004
I still have the rattle I think you're talking about. It actually happened after the head swap, so I thought it was something loose. Can't figure out what tho. It also seems to go away once it gets warm.
Old Aug 31, 2004
Okay, I may have found a solution. Do you have a neuspeed strut bar? Mine was hitting the R134A refrigerant hose and causing it to vibrate. I put some soft foam between it and the sound went away I think. It could also be the hose touching the hood if you don't have the bar installed.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
frisbeeguy2
Jul 30, 2015 03:00 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
1khilari
Jul 9, 2015 08:12 PM
