Dual purge setups
Old Aug 24, 2004
halflife's Avatar
halflife is an unknown quantity at this point
Dual purge setups
Does anyone run a dual purge setup. Basically for cosmetic reasons only, I would like 2 purge clouds shoot out instead of one. Is there anyway to attach a split Y to the purge pipe on a NX kit?
Old Aug 24, 2004
ImportRacer2123's Avatar
K20 Member
I had it on my car here are some pics
Old Aug 24, 2004
halflife's Avatar
Thanks how did you do it?
Do you have 2 selonoids?
Old Aug 24, 2004
K20 Member
no i am boosted now I sold my Nitrous kit a while back. i Just T both lines.
Old Aug 24, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
One selenoid
take the selenoid to ACE hardware goto the gas fittings rack and get the connectors, T fitting and cooper lines.
They are very helpfull there and should be able to help you with all measurements.
If you look close on this picture you'll see the actual set up from the selenoid on the top left to the T fitting on the top middle.
Old Aug 24, 2004
halflife's Avatar
Originally Posted by Supermex
One selenoid
do you think i could just put a Y fitting on the end of the NX purge pipe?
and what intake manifold is that? Nice setup!!
Old Aug 24, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
hey supermex.. been meaning to ask u... what TB/IM is that.. was it bolton??.. how does she run??... any improbvement over the stock??
Old Aug 24, 2004
civic01vtec's Avatar
it is from a mustang.........custom fitted
Old Aug 24, 2004
what has to be custom fitted.. the screw alignment??..
Old Aug 25, 2004
supermex's Avatar
X:
The IM was custom made and to get the TB to fit on it a plate with the right aligment from the TB was welded on to it.
You can do it with any other TB I just got the Mustang GT racing cause it is 75mm diam.
It works good for me but I'm running on low compresion pistons so I'll not be able to see any real performance till I tutbocharge the beast.
HALFLIFE:
Y fitting will also work but you'll still have to get the lines and fitting to go out were you want them.
And with the Y it will requiered another bend on the piping as with the T is a straight shoot out to the sides.
There is different ways to do it I just found it easy for me to do it this way myself.
Old Aug 25, 2004
halflife's Avatar
My purge tube comes out right in the middle of my hood by the windshield. I am thinking I can just attach the Y fitting to the end of it and be done.
Old Aug 25, 2004
supermex's Avatar
Well, that's your answer.
Old Aug 25, 2004
nocturnal 1's Avatar
nocturnal 1 is an unknown quantity at this point
does anyone out there own a tsi extreme turbo kit???
Old Aug 25, 2004
kezay's Avatar
kezay is an unknown quantity at this point
Supermex how is that TB and IM working for you ???? what sorta gain have you realized. and how does it idle? What price did you pay for it and was there any custom welding involved?? I love it and I want it if it works good.
Old Aug 26, 2004
supermex's Avatar
It idles good as long as the map sensors is pluged in.
And it was made for turbo so I'll find out when I get it.
Mine will cost you about $1200.00 just for the IM/ TB is custom made you'll have to wait to have it made and will lose Cruise control.
Call Phil @ (321) 403- 7833 he was an active member BARNEY
He is got a customized Venom IM/TB fuel rail and injectors for sale
very cheap.
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
