Need some quick help installing my hayames...stripped bolt...
Old Aug 22, 2004
Seabass's Avatar
Seabass is an unknown quantity at this point
Hey everyone, ok i was working on getting my coils off but when i tried to get off that screw that attaches the coils to the brake line then i couldnt get it. Then i kept on trying to get it off but now its stripped, it should be a 12mm socket but it wont work now and ive tried with all of my tools, and i have no idea wtf to do. Someone please help, thanks.
Old Aug 23, 2004
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Grind a slot into it with a Dremel and use a screwdriver.
Old Aug 23, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Easiest way, I did it too... Get your favorite CORDED drill (Unless you've got an 18+ Volt Cordless) and a set of bits suitable for metal... drill the head off. It probably takes about a 3/16-1/4 Bit, then stick a screwdriver on the side of the head and smack it, it should snap off. If I remember right the replacement was a standard M8x1mm bolt.
I don't like the idea of a cutting disc right next to the brake line... you don't want it slipping.
Old Aug 23, 2004
v8eaterokv6's Avatar
i have a new home do u
you could also file two flat sides on the head and use vise gripes to get it off
Old Aug 24, 2004
MadWheel's Avatar
Premium Boosted Member
or cut a square edge on the head of the bolt with a dremel, then take a gator grip to it...
I would have never thought that bolt would strip though... the torque on that bolt is minimal
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
manicEL
Dec 10, 2001 06:33 PM
