Adjusting Internal Wastegate...
Old Aug 22, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
I wanted to know ho to open the Internal wastegate of the SF kit so i couldonly boost up to 5 psi....
here a pic......
Old Aug 22, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
it should come with a boost controller with two rubber hoses attached to it... I'm no boost junky but I believe that's where you adjust boost!...
Old Aug 22, 2004
ImportRacer2123's Avatar
K20 Member
If it did come with a boost controller, but the wastegate is set at say, 7 psi, it wont matter that the boost controller is there. The boost controller cant make it open at a lower psi than the wastegate actuator does, only a higher psi. If you want to open lower than the actuator is currently setup at, you have two options. A: replace the actuator with one that opens lower, though I am not sure why you would want to only run 5 psi. B: Bend the arm of the actuator to get it to open this is a trial an error thing I wouldnt recommend.
Old Aug 22, 2004
Balut Eating Champ
damn thanks man... I didn't even know that I thought it's all in the boost controller and internal wastegate is set to 0 LOL isn't it scary, that i'm boosting today, and I only know just the basics about turbo hey thanks bro!
Old Aug 22, 2004
VinylPlaya04's Avatar
VinylPlaya04 will become famous soon enoughVinylPlaya04 will become famous soon enough
LOL that was actually me who posted that, but no problem, glad to see I could be of service.
Old Aug 22, 2004
weel suposedly these actuators are adjustable, i think i adjust it with the nut, but i dont know witch way is lower or higher.....
Old Aug 22, 2004
If its adjustable its just adjustable in how far it opens. usually the shaft from the actuator to the flapper arm is threaded so you can extend or shorten it
Old Aug 22, 2004
civic01vtec's Avatar
right.........the rod coming from the actuator to the flapper in the downpipe adjust the boost. Loosen the nut and take the rod off of the flapper on the downpipe.
To lower the boost, turn the rod and make it longer.
To raise the boost level, make the rod shorter.
Then reattach to the flapper
Old Aug 22, 2004
MadWheel's Avatar
Premium Boosted Member
Bout time someone gave the right advice for this issue! On SF internally gated turbos, they come with progressive wastegates. Meaning you can adjust the boost but lengthening or shorthening the wastegate. As stated earlier, shorter means higher boost, a longer rod means less boost.
Tedverseti
Sep 29, 2015 05:41 PM
C-Hamm
Sep 28, 2015 10:31 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
