can someone explain these power ratings to me plz?
Old Aug 16, 2004
Premium Plus's Avatar
Ninja Crew
Premium Plus is just really nicePremium Plus is just really nicePremium Plus is just really nicePremium Plus is just really nicePremium Plus is just really nice
dont understand too well, but im wondering what the RMS wattage is on this amp. its an MTX thunder 302.
here are the ratings according to MTX:
RMS Power measured at 12.5 Volts DC:
75 Watts x 2 into a 4 Ohm load with less than 0.05% Thd+N
150 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
300 Watts bridged into a 4 Ohm load with less than 0.1% Thd+N
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
120 Watts x 2 into a 4 Ohm load
212 Watts x 2 into a 2 Ohm load
425 Watts bridged into a 4 Ohm load
Signal to Noise Ratio:
110dB A-Weighted
so is it a 150 watt rms per channel? or 75?
is this a decent amp to power 2 kenwood 12" subs?
Old Aug 16, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Its both. Depends on the resistance you have the sub wired to.
Old Aug 16, 2004
Ninja Crew
the resistance? sorry for the noob question but can you explain that? how do i control the resistance?
Old Aug 16, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
i dont think you control it, just get the type of speakers you want.
Old Aug 16, 2004
takumi's Avatar
takumi is on a distinguished road
Ya, it all depends on what the specs on the subs are. What model subs are they?
Old Aug 16, 2004
MegaHurtz's Avatar
You get the higher power ratings out of that amp (or any amp for that matter) by wiring your subs down to a certain "ohm load".
Your ohm load is the resistance that your subwoofers are presneting to your amp, and with a lower ohm load, you are showing your amp a lower resistance, and with less resistance it will put out more power.
For example, if you are stepping on a water hose and only 1 gallon of water a minute is coming out, and then you take your foot off and 10 gallons a minute start coming out, that is because there was less resistance in the hose.
Make sense?
You control the resistance by wiring your subs a certain way. If you have single voice coil 4 ohm speakers (the most common kind), you can wire them one way to get 2 ohms and another way to get 8 ohms.
Old Aug 16, 2004
Ninja Crew
the subs are a pair of 12" Kenwood KFC-3005
not too sure about the specs
Old Aug 16, 2004
MegaHurtz's Avatar
Check the Kenwood site if they are a current model
Otherwise use www.google.com
Old Aug 16, 2004
MegaHurtz's Avatar
Where in Canada are you at?
Old Aug 16, 2004
Ninja Crew
Make sense?
ok...makes sense. how can i wire my subs to get max ohm load?
Old Aug 16, 2004
Ninja Crew
im just outside of toronto mang
but i used to llive in vancouver
moved away about a year and a half ago. i miss it out there
Old Aug 16, 2004
MegaHurtz's Avatar
Well if you want more power you want a lower ohm load
Use this site to help you figure out your wiring:
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Long story short though, if you want a 2 ohm load, you need to go from + on one sub to + on the other and from that + go to to your amp
Same goes for negative
+ ==== + ===== amp
- ==== - ===== amp
^^ half-assed wiring diagram but hopefully you get the idea
Old Aug 16, 2004
Ninja Crew
this looks like the specs on the sub:
Frequency Response: 25Hz - 800Hz
Impedance: 4 ohms
One-Piece Cone Design
Pearl Mica Injection-Molded Polypropylene Cone: 12"
Tornado-Type
Power Handling: 700 Watts
so after reading that...does the MTX look like a good amp for those subs? im still kinda lost on all this **** lol. im a total noob :S
Old Aug 16, 2004
MegaHurtz's Avatar
I think that MTX amp is a little small... if Kenwood is claiming 700w of power handling, that appears to be peak, so the RMS is likely around 300-350, so try to maybe find something 6-700 watts
Old Aug 16, 2004
Ninja Crew
nice one...thanks for all the help mang.
man, im havin a hard time finding a good deal on an amp thats good for my subs :S
Old Aug 16, 2004
MegaHurtz's Avatar
Ya high powered amps are costly..
Old Aug 16, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
if you want bass but not neccessarily the loudest of the loud, you can save a lot of money if you buy a cheaper amp...ie...one that outputs 300watts rms instead of 600watts
3db louder is barely noticeably louder. to raise the spl by 3db, you're doubling the power. note that ported boxes are aprox 3db louder than sealed, and having a 2nd sub is also 3db louder than only one sub. doubling the power or subwoofers will not make your setup sound twice as loud.
Old Aug 16, 2004
MegaHurtz's Avatar
Naw you'll need roughly 8x the power to get twice as loud (as you know, +10db = twice as loud )
I don't think this guy wants to go that extreme
Old Aug 16, 2004
Ninja Crew
so you think that that mtx will give me decent bass. not the best amp for those subs, but should be ok?
or is it a waste of money, and i should wait till i find a good deal on one that will give me more power?
Old Aug 16, 2004
Ninja Crew
your right, i dont want to go crazy...i just want some nice loud bass
Old Aug 16, 2004
MegaHurtz's Avatar
I say wait until you can afford more power, you don't want to under power your subs that much, that's bad for them and the amp
Old Aug 16, 2004
Ninja Crew
hmm...alright...cheers man
Old Aug 16, 2004
turboslug's Avatar
Super Hoser
you wont hurt the subs if you dont run them at their maximum power capability
it wont hurt the amp either unless you try to push the amp beyond what it is able to handle..
Old Aug 17, 2004
takumi's Avatar
Underpowering subs can cause them to blow, trying to draw too much power from an amp will cause it to clip.
Old Aug 17, 2004
turboslug's Avatar
Super Hoser
clipping is not the same as underpowering.....
underpowering is like only putting 20watts into subs that can handle 300watts. it will not damage the sub at all. if subs blew everytime you put less power into them than their rated maximum rms, you'll be blowing subs everytime you turn down the volume..lol...as everytime you turn the volume down, you are decreasing the power output.
clipping is different than underpowering. you get clipped signals from trying to produce a voltage higher than the souce voltage of the amp. this can happen in a deck's amp or the external amp. when you are trying to produce more power than what the amp is capable, you get a distorted output signal that is "clipped" at the top and bottom of the sine wave.
Old Aug 17, 2004
MegaHurtz's Avatar
He was saying that underpowering causes clipping, not that it is the same as clipping
Old Aug 17, 2004
turboslug's Avatar
Super Hoser
there are lots of ways to cause clipping. you cant say it's just trying to push the amp beyond what it is capable of producing.
lets say you had a cheap to middle of the line deck with a volume **** that goes to 40. if you turn the deck up all the way up to anywhere near 40, chances are you'll be sending a clipped signal to the subs even if the amp is not outputing maximum power.
there are lots of things that can cause clipping. ie. the deck's volume **** turned too high, gain settings, the tone settings, music source, etc.
to minimize the chances of clipping, you can calibrate the gain of the amp to match it with when the volume of the deck is all the way up. you can also use your ears. minor clipping wont be obvious(nor will it do major damage right away) but some people turn their systems up so high that it's obviously distorting.
Old Aug 17, 2004
Ninja Crew
well after looking into the subs a little further, it looks like they have a max rms rating of 175
so i guess that mtx amp is an alright amp for them afterall?
Old Aug 17, 2004
MegaHurtz's Avatar
The only way you can wire them is to 2 ohms, which would be too low for that amp. It is 2 ohm stable which means you are only able to bring it down to 4 ohms in mono mode otherwise it will go into protection and possbily destroy the amp.
You need to look for an amp that does 175-200wrms @ 4 ohms, OR find a 1 ohm stable amp that puts out around 350-400 watts at 2 ohm mono, OR your best option is to find a monoblock (one channel) amp that puts out 350-400 watts RMS @ 2 ohms
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
fordover
Jul 11, 2015 09:10 PM
jody501
Jul 10, 2015 11:01 AM
ZILLA
Jul 5, 2015 05:24 PM
