Clearing Headlights: Check List
Old Aug 16, 2004
Tdoan14's Avatar
Tdoan14 is a jewel in the roughTdoan14 is a jewel in the roughTdoan14 is a jewel in the rough
Well yesterday I was seeing if i could take the bumber off and put it back on. Today I will be clearing the lights. Does it look like I have all the tools necessary to complete the process? Does the bulbs look good and did I get the right silicone? I might be using a hair dryer instead of the oven...
Old Aug 16, 2004
dirtySAMURAI's Avatar
I log in from time to time
looks like you got everything.
Old Aug 16, 2004
civicstyle82's Avatar
civicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to all
Looks like it, I did mine last summer on an insanly hot day and I didn't even have to use anything to get it apart.
Old Aug 17, 2004
dariusld's Avatar
dariusld is an unknown quantity at this point
Has anyone only did half the orange lense? I thouhgt that might clean it up a little and still be legal.
Old Aug 17, 2004
Looks good. Don't do half, just take the whole piece out. Oh and the oven is a must. I was clearing someone's lights a month back and couldn't get them open. We had to ask a neighbor to use their oven!
Old Aug 17, 2004
civic01vtec's Avatar
i have seen some members do that............cut the lenses
Old Aug 17, 2004
armieo has done the half orange thing....
Old Aug 17, 2004
Tdoan14's Avatar
well i had trouble getting one of the four bolts off the headlights, i didn't have a socket wrench with 10mm extension thingy. so i had to put the bumper back on once again and go buy it at autozone. i was going to do it today but school started today. i might do them tomorrow or friday.
Old Aug 17, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Looks pretty complete, but if you can, try to find Permatex Gasket Maker sealant. I've had no problems using this stuff instead of the regular silicone sealant.
Also, try to find some spring clips/clamps from your local hardware store. Once you have cleared the lights, put the reassembled, unsealed lights in the oven for a couple of minutes at 350F then take them out and immediately use the spring clamps to close up all the seams. THEN run the Permatex around, for a leak-free seal. Using this method, my lights have not fogged up after storms, direct pressure washer hits, and being yelled at repeatedly by bag ladies.
Old Aug 18, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
i was thinking of clearing mine at first, but i decided to black them out instead
the most time consuming part for me, was getting the headlights apart. i was worried about leaving them in the oven for too long
Old Aug 18, 2004
silvrbreez02's Avatar
silvrbreez02 can only hope to improve
Be careful when taking out the chrome trim to get to the orange lense. If you get any of that tar sealent on that chorme trim it is a biotch to get off . Trust me...I know. I ended up rubbing off some of the chrome trying to clean it, so I just went and blacked them all out. Looks damn good too...I'm actually glad I got some of the tar on mine . Anyway, just thought I'd give a head's up.
Old Aug 18, 2004
Mr.Modify's Avatar
awwwwwwwwwwwwwww he printed out the page ....haha....loooks like you got everything though.
Old Aug 18, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
ahhaha
btw if your gonna paint it black instead should i take off the chrome first?
looks like simple green can get it out. i dripped a little bit on accident on the chrome while cleaning the lens and it took the chrome right off.
Old Aug 18, 2004
I'm not sure you need to get all the chrome off, whatever paint you choose (I went with Duplicolor Automotive Flat Black) should stick pretty good. I would definitely use a coat of filler primer on it first though to make sure the paint sticks. I just went ahead and roughed it up a little bit with some 800 grit sandpaper just to make sure, and put down one coat of filler primer.
Old Aug 18, 2004
TeLLy's Avatar
Or just buy some Krylon Fusion, which is made for plastic, no need to sand.
Old Aug 18, 2004
Mr.Modify's Avatar
or primer paint to..........
Old Aug 18, 2004
Yeah I heard of that stuff. Does it work pretty good? I was just using what I already had...trying to save a little dough.
Old Aug 18, 2004
Mr.Modify's Avatar
primer paint? hell yea it does!
Old Aug 18, 2004
No not primer paint...I know that stuff works. I should've been more specific...I was wondering how good the Krylon Fusion that Telly was talking about works?
Old Aug 19, 2004
LilCivicGirlie's Avatar
Girlfriend of Resident RSX'er
LilCivicGirlie will become famous soon enoughLilCivicGirlie will become famous soon enough
I didn't even use an oven or hairdryer. I just set it outside for about 45 minutes and thats it. Still no leaks or anything to this day AND I live in a fairly growing town with lots of 7thgens...I'm still the only one with cleared headlights lol. I wonder if i can somehow put up an ad and I'll do it for a price
Old Aug 19, 2004
No oven or hairdryer here either...of course I am in South Louisiana (hot as the f***). I just pryed those badboys apart no problem.
Old Aug 20, 2004
ry's Avatar
ry
darkness
ry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of lightry is a glorious beacon of light
half clear doesnt look bad
Old Aug 20, 2004
hustlelikem0fo's Avatar
no, you're missing one thing. masking tape. when you pull out the insert from the lense put the masking tape on the edge of the lense so you wont get that black **** on the chrome insert
Old Aug 22, 2004
Tdoan14's Avatar
on step 9 of the diy, it says remove the two phillip screws. well my phillip's screwdriver doesn't seem to fit it. what am i supposed to use?
ok... i just did a search. it's not a phillips screw, it's a torx screw right?... if so what size?
ok... i did another search. t10 is the size? i found a t10 in my garage but it doesn't seem to fit it... (is my torx driver screwed up?)
Old Aug 22, 2004
Tdoan14's Avatar
IM DONE!!! I'll probably get hyper whites later on...
Old Aug 22, 2004
chrisleecool's Avatar
I don't really like cleared headlights on a black car (i've done it, but I didn't like it so i blacked'em out). i'll give you " " for ur work
Old Aug 23, 2004
specter542's Avatar
I'm NeonImpact's a55hat!
specter542 should not be trustedspecter542 should not be trustedspecter542 should not be trustedspecter542 should not be trusted
looks good dude.
now lower that bitch
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
trellex
May 24, 2015 04:39 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
