LED Gauge Mods - Update
Old Aug 9, 2004
ELaudio's Avatar
ELaudio is an unknown quantity at this point
This project has dragged on for many months now. Mostly because I've been busy with work, stuff outside of work and doing other mods to my car. But, as a teaser for now, I'm posting up some pics of my latest work.
I've connected everything below up to my cluster and it's DAMN bright. about 2X as bright as my original setup. I am now using a total of 103 LEDs to light up my cluster; 16 for the needles and the balance for each gauge.
I'm using three colours: Blue (Main colour), White (for the MPH on the speedo) and Red (for the #7 and #8 and the red band on my tach, and the "E" and "H" on my fuel and water temp gauges, respectively.
What I don't have pics of are how I've lit my needles. I'm using 4 3mm LEDs per needle. I basically drilled out holes around the clear plastic housing right underneath the where the needle sits, and used cyanoacrylate glue to hold the LEDs on. Had to shave them with a dremel tool to prevent interference with the stem of the needle, though.
SO... All I have left to do in "encase" the RED and WHITE areas, so light doesn't leak out everywhere. Right now I have everything plugged in and my tach looks crazy - fades from blue to Red (but it's ugly, IMO)....
Let me know what you think.
Front of the Speedometer Gauge Insert
Rear of the Speedometer Gauge Insert
Speedometer Gauge Insert, Lit-up.
Front of the Tachometer Gauge Insert
Rear of the Tachometer Gauge Insert
Tachometer Gauge Insert, Lit-up.
Front of the Fuel Gauge Insert (note: the fuel gauge and water temp gauge inserts are identical)
Rear of the Fuel Gauge Insert
Fuel Gauge Insert, Lit up.
I'm going to shave down each LED using my trusty dremel tool. I'll post some more pics of the final assembly (hoping to do that tomorrow night) and the finished product... At any rate, this should be complete by the week-end.
Old Aug 9, 2004
Keep this updated. Mad props to you for going into so much detail. I just put a fourth EL wire kit behind my gauges and I'm finally happy with the brightness. You're gonna enjoy it once everything is all done.
Oh I'll make this a sticky thread for ya.
Old Aug 10, 2004
ELaudio's Avatar
Wow - I guess you stickied it!
I've thought about this, I've probably spent over 120 hours in total working with LEDs in my interior. Too much time - I just want to get this DONE.
Old Aug 10, 2004
ELaudio's Avatar
UPDATE: Had a minor set-back tonight. I decided to sand down all the LEDs to improve light diffusion. Used a dremel tool, have done this in the past when I did my A/C and ventilation controls. Problem is that I got over-zealous with the Dremel and broke into the diode junction. Damn. So, I have to swap out about 4 or 5 LEDs. Kind of a bitch because a lot of them are held in with cyanoacrylate. So, I drilled them out and will have to work through the mess of wires to get it back... so, odds are this may take me several more days/evenings of building.
Project is looking good, though. I had all 103 LEDs hooked up for the last 2 days in my cluster and everything worked OK - no smoke, heat or fire! So pretty much all I have left to do is fix those over-sanded LEDs, sand them again and do the tedious task of final assembly. I have a few interesting tricks up my sleeve on how I'll do that. A bit hard to explain here - I'll post some pics to explain my assy. process.....
Old Aug 10, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
looks good, sanding the LEDs spreads them out a little better, the light that is.
Old Aug 11, 2004
ELaudio's Avatar
I sanded all the LEDs. Definitely spreads the light out better but you do lose some intensity as a result. I guess you really can't cheat the laws of physics. This is quickly turning into my blog on the gauge build!!!
Tonight I fixed the LEDs I over-sanded last night. Had to drill some out, re-installed, used some cyanoacrylate here and there and all the inserts are working 100% again.
At one point I kinda got freaked - the wiring/soldering does get a bit tricky:
Unfortunately, the gauges are on hold until at least Saturday. I'm playing hockey tomorrow night and have a date on Friday. So, for now, I hooked up my needles so I can see my gauges at night....
Details to follow...
Old Aug 12, 2004
gh0st's Avatar
TAQUITOS!!!!
wow. let us know how it all goes...er...the LEDs...not the date
Old Aug 12, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Martin, you are god. Next to gearbox, who I proclaimed god first for helping me with where to mount my ballasts. But hot damn is this gonna look sweet.
I saw the original setup, and that already was beyond pimped - can't wait to see the new and improved product.
Old Aug 12, 2004
ImPulse's Avatar
Nice man! Cant wait too see the finished product! You seem to know a lot about LEDs? Or at least understand them a little bit? Do you have a screen name?
Old Aug 12, 2004
ELaudio's Avatar
I'm ELaudio... I learned how to solder at a young age (lol). Actually, I took a lot of electronics courses in high school. Went on to get a degree in Mechanical Engineering which furthered my knowledge of electronics.
I'd have to say that my approach is not for the faint of heart. But, the actual circuits involved are incredibly simple; (negative--->LED--->LED--->LED---->Resistor---->positive). All I do is keep repeating that, with different #'s of LEDs and resistor values, put them all in parallel and that's it. The HARD part is building the damn thing and soldering it all, making sure nothing is shorted out and fitting it all into the cluster itself...
Old Aug 12, 2004
My brain shut off when you said "led" and "parallel" in the same sentence. I only deal with series I'm waiting for the final pics. I can't believe you did all that work. It's gonna look so nice when you're done.
Old Aug 21, 2004
ELaudio's Avatar
Well... I'M DONE! At least for now... Have a few issues right now: mis-wired the capacitor for headlight reminder buzzer so it's not working too hot. I'd also like to diffuse the light behind the odometer a bit better. Ahh well, still looks really sweet.
At night, it's freaking blinding. I drove around last night around 1:00am to test them out, had to crank down the brightness.
Old Aug 21, 2004
OMG are you kidding me that's so amazing!!
Old Aug 21, 2004
gh0st's Avatar
TAQUITOS!!!!
where's my "that's so freakin cool" smiley..
Old Aug 21, 2004
ELaudio's Avatar
Unfortunately, the pics just don't do it justice. I'm going to try to take better pics, but try as I might, I couldn't get a reasonably decent shot (except for the one I posted). My digital camera has a pretty awesome macro (close-up) mode, but whenever I take pics in that mode all I see are the scratches on the clear plastic piece that protects the gauges. What's weird is that I don't see these scratches unless I REALLY look for them...
I think for now I'm going to put this project on the shelf. There are a few minor things I want to fix, but those can wait. Funny, I think I left a sliver of electrical tape over the symbol for "Fasten your seatbelt", because the dude is missing his torso (just a head and legs). heehee...
Final thoughts on the project: I went overboard and it took me a **** load of time. I think I started this project back in early april, been doing it off an on for the last four months. It's not that difficult to do if your skillful with a soldering iron and know a bit about electronics. It's just very, very time consuming. I think gearhead's way of using EL cable is a far easier method. The key problem is that an LED is essentially a point-source of light, and you're trying to diffuse it as best you can. The way I approached this problem was too use a LOT of LEDs, like over 100, to get even light coverage. What's funny is that the total current draw is probably LESS than it was when I was using the 7 incandescent bulbs to light up my gauges. That's the beauty of the LED - almost unlimited lifespan, very efficient power-wise, doesn't generate much heat. I can see why so many newer cars are going to LEDs for their gauge clusters...
Take care all - if you plan on doing any gauge mods feel free to PM me. I know pretty much everything there is to know about my cluster. Mind you clusters will vary. The one I have is unique to the Acura 1.7EL, but my "generation" (large tach and speedo) all have the same circuit board. When I was working on the project, I noticed that the clear light-guide and circuit board had spots for the PRND321 for auto trannys...
Old Aug 21, 2004
ELaudio's Avatar
Here's a couple more pics for you.
This pic shows all four LED inserts in the correct position, prior to attaching on the white plastic frame and circuit board.
Here's a close-up of the finished product. Note the high-beam indicator for a comparison of the intensity. Like I said in my last post, I'd like to (eventually) fix up the lighting for the odometer. Looks kinda ghetto right now, but it will have to do. I am so sick of LEDs at this point. I love them, but I hate them too. lol. What you can't see too well in the pic is that the numbers on the speedo in km/h are blue and the ones in mph are white. It's very noticeable when seen in person, but I guess my digital camera had some issues with picking up the colours. Also, the red-zone of the tach is very, VERY bright and RED. I think I used something like 10 LEDs just to light up the numbers 7 and 8, along with the band beside them.
Old Aug 22, 2004
ImPulse's Avatar
thats awesome man! but... look at the back of that thing... I wouldnt know what to do? hahaa
Old Aug 22, 2004
TeLLy's Avatar
Hey bud, it looks great. Now do mine, LOL. No seriously man, that's an amazing amount of work. Props.
Old Aug 22, 2004
Heh yeah you should see mine. Fricken mess back there or wires and glow wire and who knows what else. Oh yeah like 10 wire splice things on hte thin stock illum wire.
Hey, one sortof problem I had is that the icons like seatbelt and fars don't light up well. When one is on, the light bleeds through and lights up a few more icons. Not really an issue, since I hardly use fars and always use seatbelt. Ohwell, not a big deal.
Old Aug 25, 2004
ELaudio's Avatar
The key thing is that I colour-coded all the wires. Well, there were really only two colours, black for negative and red for positive. It was then just a matter of soldering the huge-*** splice onto the circuit board where the stock bulbs used to be. I still can't believe I managed to cram all that **** inside my cluster. The back plastic piece bulges out because of all the wires, but who cares...
Well, they've been in for a week and are still working great. No smoke, fire, burnt-out components....
Old Aug 25, 2004
VtecViXen
Guest
Posts: n/a
omg thats fricken tight! wish you were around here, to show me whats up! mad props..
Old Aug 26, 2004
03AzNsIlvaSeDaN's Avatar
03AzNsIlvaSeDaN is an unknown quantity at this point
wow thats really nice...props for doin all that work!!
Old Aug 28, 2004
ELaudio's Avatar
Like I said, it was definitely a labour of love. Although near the end I really, REALLY got sick of LEDs. lol. From what I've learned, I could probably do a cluster in 1/4 the time it took me. So - any offers on custom clusters by ELaudio??? Nah, never mind. The LEDs probably cost me about $70 when all was said and done. The real cost was in the labour. If I (ever) get time I'd like to post up a DIY or more detailed pics. If someone could host them I'd post them up. I have a **** load of pics from start to finish...
Old Aug 28, 2004
ELaudio's Avatar
I guess no one noticed/commented. I autographed the Speedo and Tach inserts.
Old Sep 20, 2004
civices8353's Avatar
civices8353 is an unknown quantity at this point
Very nice, But perhaps I might try that and be the first one in Thailand.
Old Sep 20, 2004
paradoxblue's Avatar
tight. you got a pm.. i have a quick question
Old Sep 20, 2004
TeLLy's Avatar
I thought it was just scribbles. I really like what you've done here...I wanna do mine in hyperwhite and red....perhaps if the car goes back in the shop I can yank el clusterino and do something similar.
Old Sep 26, 2004
Ocelaris's Avatar
Ocelaris is an unknown quantity at this point
Those Gauges look sick :-) excellent job, especially mounting with acrylic.
Old Oct 2, 2004
blu03civic's Avatar
blu03civic is an unknown quantity at this point
If i knew anything about anything about anything that is going on in those pics and what you said, id do it in a heartbeat. Id love to have yellow and red gauges. but i would have no idea on what to do. But it looks awesome.
Old Oct 19, 2004
SomeDoodToo's Avatar
SomeDoodToo will become famous soon enoughSomeDoodToo will become famous soon enough
Wow thats Freaking hot
