makeshift component?
Old Aug 9, 2004
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
I've got some infinity 6.5s with the tweeters built on, and i think the tweeters blew (when i listen to music there is no high end), i was wondering if i picked up some infinty 10.2ts or something if it would work good
Old Aug 9, 2004
MegaHurtz's Avatar
What are infinity 10.2ts?
If you used the woofer and tweeter as a 2 way component set and got an x-over for them it would probably work pretty good
Old Aug 9, 2004
booba5185's Avatar
their the mountable tweeters that infinty makes that you can buy seperate
Old Aug 9, 2004
MegaHurtz's Avatar
Ya
would sound good on seperate channels or mated to the woofer with a crossover
I am having a brain fart right now and can't remember if component x-overs are passive or active but for some reason Iam thinking passive..
Old Aug 9, 2004
doubledeuce2k2's Avatar
well they are passive
Old Aug 9, 2004
MegaHurtz's Avatar
I knew that
Old Aug 9, 2004
booba5185's Avatar
i was gonna wire it right into the 6.5s, just run it in parrallel so my amp drops to 2 ohms
Old Aug 9, 2004
MegaHurtz's Avatar
Ya you can do that too but it won't sound very good
I say wire it to 8 first and see how it sounds
Old Aug 9, 2004
booba5185's Avatar
coo, thx
Old Aug 10, 2004
Ed's Avatar
Ed
why not somehow remove the broken tweeter, find where the power connects and try connect the power to the component tweeter to there, so the crossing over will be have been all done..
also, if you want, you can build yourself a simple passive crossover for yourself.
Old Aug 10, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
note that on some 2way's, the capacitor is located directly under the tweeter. if you hack off the tweeter, so you can glue on a new one, make sure you take the capacitor off to use with the new tweeter, else low frequencies will reach the tweeters....
low frequencies will blow tweeters...
btw, i think if you buy component tweeters without woofers, you will need a highpass filter for them. ie. a capacitor in series...
Old Aug 10, 2004
you could so buy an infinity reference set online for almost the cost of a set of tweeters and crossovers. and i bet they would sound better too. i wouldn't bother with all the hassle to save maybe $20
Old Aug 10, 2004
booba5185's Avatar
i've got the reference infinitys now and the tweeters blew, i have a dx so i can't use the tweeter pods, so i'd have to mount them on the door also. as far as a crossover, that's easy, there's crossover clacs alover the net and then i just gotta buy 2 or 4 caps
Old Aug 10, 2004
i was talking about a reference component set, non coaxial. tweeters look like about 40 on ebay. 6000cs sets end up 50-60 bux. mounting tweeters in the doors isn't that tough with a hole saw.
Old Aug 10, 2004
booba5185's Avatar
ah, i was always raised with inifinity being one of the best, am i right or whats the best, yet reasonably priced??
Old Aug 10, 2004
there is no best. infinity reference have some midbass to them, but their highs aren't super sharp. there are many speaker companies out there,each with good and bad products, and someone will swear to each one of them.
Old Aug 10, 2004
turboslug's Avatar
Super Hoser
cant you buy the tweeter pods anyways and adjust the mirrors manually from outside the car?
just open up the mirrors and remove the handle thingy..heheh
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
violentpanda
Sep 7, 2015 11:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
