Autometer LED boost gauge....check it out!
Old Aug 1, 2004
opto_isolator's Avatar
This was in the works since last Nov, but I really haven't taken any pictures of it because its been in my car until tonight (thought I was getting my turbo parts back in Feb - boy was I wrong!).
Anyhow, if you can't tell - I've modified an Autometer A/F ratio gauge to work as a boost gauge. Best thing about it? It can be calibrated for whatever boost you are running. Its going to be running off of a GM 2 BAR MAP sensor, so my setup will be good for up to around 14 PSI or so (don't plan on running this high anyhow).
ID:	34620   Click image for larger version
Old Aug 1, 2004
abmerop18's Avatar
Jam out with your clam out.
neato. thats cool
Old Aug 1, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
its cool but would get confusing with your real a/f gauge... but Tight none the less... if autometer came out with a boost gauge like that but said BOOST GAUGE and had diff numbers on it now that would be BADASS!!!
Old Aug 1, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
nice opto, how did you do it?
Old Aug 2, 2004
gotti's Avatar
how u gonna read that?
Old Aug 2, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Edit- I just found the post I was looking for.
Someone took what you just did a step further, and installed the LED's in the gauge faces. One of the coolest gauge mods I've ever seen.
VW integrated boost gauge link
Old Aug 2, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
^^^ niceeeee but I still prefer the cobalt boost gauge
Old Aug 2, 2004
For my use (right now) - I only plan on running 9 PSI. 5 PSI is going to be the top dead center LED. 9 PSI will be 2 LEDs into the yellow...
Yeah, this is one of the things that I saw when I was looking for this...Its cool, but a lot more difficult to do, so I went this route.
Old Aug 2, 2004
I had to modify the gauge.....Took it apart, resoldered some things...
Not only that, but it now needs an external power supply (5 volts), which is fine because the GM MAP sensor needs one too...
Old Aug 2, 2004
HyaBoosta's Avatar
looks pretty hot.
Old Aug 2, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
It's cool. I guess once you got used to it, it would be alright. I think I'd still prefer a standard boost gauge.
Old Aug 2, 2004
HyaBoosta's Avatar
they should make a boost gauge like that though. it would be dam sexy.
bowie
Jan 21, 2018 09:29 PM
frank_kleng
Sep 29, 2015 10:55 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
