Specs For Getting JE custom Made Pistons?
Old Jul 27, 2004
ImportRacer2123's Avatar
K20 Member
Does anyone know what the specs are for custom JE pistons?
http://www.jepistons.com/pdf/customp...-orderform.pdf
Old Jul 27, 2004
Jodster's Avatar
Post Whore General
PM C2i0v0i1c and ask him. He should have the specs. I don't remember if he posted them or not awhile back.
Old Jul 27, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
or SUPERMEX
Old Jul 27, 2004
K20 Member
i thought C2i0v0i1c had Crower Rods?
Old Jul 27, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
He has JE pistons too. The Crower rods are not installed.
Old Jul 27, 2004
civic01vtec's Avatar
LOL......rods and pistons are 2 different things.......but yeah, PM Kevin
Old Jul 27, 2004
K20 Member
yeah i know dork... Jeff told me to check out the members rides for the specs but all i found was the crower rod specs... I didn't know he had JE pistons my bad.
Old Jul 27, 2004
yeah i know dork....
Old Jul 27, 2004
MadWheel's Avatar
Premium Boosted Member
I still dont see why people don't buy pistons from turbo specialties. They're dirt cheap and DSM owners love them. I plan on eventually buying them.
Old Jul 29, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Wiseco part # XT-519P76 for 76mm
I know that they make a direct bolt on 75mm also.
They are about $500.00 for a set rings about another $100.00 for rings
Wiseco an JE are quality parts, you get what you paid for.
To install crower rods you must notched the botton of the sleeves cause the rod is a lot thicker than stock.
Old Aug 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
very true on the block notching, pain in the ***, i paid 550 for pistons, pins and rings. but we already spoke of the specs and i gave them
Old Aug 1, 2004
C2i0v0i1C's Avatar
SuperMODrizd
if u get the 76mm ull have to bore.
Old Aug 2, 2004
supermex's Avatar
yes you you will have too
but I wouldn't recomended with out stainlees steel replacent sleeves cause you'll be making your stock slevees even thinner (more fragile)
The maximum factory oversize suggested is 75.52mm
Old Aug 2, 2004
HyaBoosta's Avatar
so does anyone make 75mm pistons that will fit without having to bore out the cylinders?
Old Aug 2, 2004
C2i0v0i1C's Avatar
SuperMODrizd
depends if u want high or low compression
Old Aug 2, 2004
HyaBoosta's Avatar
low compression
Old Aug 2, 2004
supermex's Avatar
Wiseco makes them stock dims
carid
Nov 7, 2015 01:46 AM
Butterfli13
Aug 12, 2015 11:04 PM
cukaracha
30
Jul 26, 2015 12:01 PM
Jul 12, 2015 11:54 AM
fvckbg
Jul 7, 2015 07:08 PM
