im depressed and upset...
Old Jul 22, 2004
bakablo's Avatar
bakablo is an unknown quantity at this point
after installing my turbo...... everythign ran fine..
stupid me.. I had to go try to install my vafc.. I installed it... was pretty good... but when I adjusted my settings on my vafc.. i went for a ride around the block with half a tank... and my car started idling weird.. not wanting to push... smelled liek gas... ALOT!!! by the time i got close to my house I ran out of gas.... and car shut off... I went home got some more gas.. put it in.. car doesnt start... towed it home.. not i just finished towing it to the sop.. the guy says my engine isnt blown... he said it might just be congested with alot of fuel.. I hhope everything is alright.. and opinion or thoughts?
I had my vafc at around +3 +2 +1 +2 never over +4
Old Jul 22, 2004
I've had mine turned up like that, but nothing bad happened. Especially with a turbo, I don't know how more fuel can cause a problem. Our cars actually run rich from the factory. Are you using an fmu or something? Vafc won't be enough to work with the turbo by itself.
Old Jul 22, 2004
djmota's Avatar
sounds like a fuel line/hose problem to me, especially if you smelled gas under the hood. check your fuel rail and hoses for leaks.
Old Jul 22, 2004
bakablo's Avatar
i have a vafc and rsx type S injectors
Old Jul 24, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
If I were you I would install the stock injectors and then run it. I know you probley already know but with out the emanage I wouldt be switching out injectors just yet. Also did you have a return fuel system set up?
Old Jul 24, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
never ever blindly use an afc
Old Jul 24, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Mabey your car was running too rich because of the bigger injectors? Vafc needs to be dyno tuned.
Old Jul 24, 2004
bakablo's Avatar
well... regardless now my ecu is fried...
cferry7
Oct 18, 2015 06:32 PM
BJB
Sep 14, 2015 11:16 PM
thaler4cuse
Sep 7, 2015 08:25 PM
tommycanada
Sep 5, 2015 04:59 PM
GritzNGravy
Aug 19, 2015 03:03 AM
