Size for speakers?
Old Jul 20, 2004
eetfunk's Avatar
eetfunk is an unknown quantity at this point
Arrow Size for speakers?
Hi!
I'm looking to replace the company speakers in my 2003 Sedan Civic. I'd like to know what size of speakers it takes for the front and for the rear.
Also, any suggestions? I'm looking for a great sound, but don't want to spend a couple of K's on this!
Thank!
eetfunk
Old Jul 20, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
sedan: 6.5" front and rear
coupe: 6.5" front, 6x9" rear
Old Jul 20, 2004
eetfunk's Avatar
Thanks
Old Jul 20, 2004
Danman114's Avatar
Danman114 will become famous soon enough
watch out for the depth in the fronts... to deep of a speaker will require a spacer. My rocks took a 1 inch spacer...
Old Jul 20, 2004
eetfunk's Avatar
I'm currently looking at 2 1/8" and 2 3/16"
Will they fit? I don't get it... why could I need a spacer? because of the tweeter coming out of the speaker?
Thanks for answering a car audio newbie
Old Jul 20, 2004
Danman114's Avatar
if you were putting 6.5 inch speakers in the front, some of them are really deep. stock speackers are like an inch - inch and a half. My rocks are a good 4 inchs deep. With out a spacer they would hit the door (the back of them) and in turn not let the window roll down all the way... I have no idea about the size speakers your looking at... oh well.. .time to go home for me
Old Jul 20, 2004
zen_master's Avatar
THANX!
i just happen to need that! learn new stuffs everyday...
anyway, that number should be PERFECT bolt on, right??
Old Jul 20, 2004
turboslug's Avatar
Super Hoser
i would say all aftermarket speakers for the front doors will require a spacer
the hole is not a circle. even cheapie speakers will not fit the hole without the spacer. the basket will hit the sheetmetal
Old Jul 21, 2004
eetfunk's Avatar
Where can I get such a spacer? Should I just make my own?
Anyone replaced the front speakers in a 2003 Sedan? Will 2 3/16" fit?
Thanks!
Old Jul 21, 2004
brash's Avatar
brash is an unknown quantity at this point
People here have put in 3" speakers in the front, so 2 3/16" should be fine. You will probably need a spacer, though. You can buy spacers (try CarDomain), or you can make your own (I made mine out of 7/8" MDF using a jigsaw).
Old Jul 21, 2004
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
Or you can do what my installer did and cut the opening in the door. My speakers were so deep that they wouldn't fit at all without trimming the opening for the stocks. I don't regret it one bit, plus if done right the stocks will still fit in the expanded opening.
Old Jul 22, 2004
Flounder's Avatar
Flounder is an unknown quantity at this point
Drop-In...
I'll have to check with my installer (going there on Friday anyways to get my new alarm and double 12" installed), but I think my Eclipse 8363s were drop-ins.
I'd have done a DIY, but I like having a 3-year warranty.
-Flounder
Old Jul 22, 2004
eetfunk's Avatar
What's a good pair of speakers to put in my ride? I listened to the Infinity's 6002i and 6.25i and I wasn't impressed.
Thanks
Old Jul 22, 2004
I have Boston Acoustics SL's...zero complaint, even made stock HU sound much much cleaner...mine were about 675 with install
Old Jul 22, 2004
MegaHurtz's Avatar
The rears in a sedan are 6.5?
Old Jul 22, 2004
brash's Avatar
Yes.
I think there are about 4 million other threads that have stated the different sizes, too...
Old Jul 22, 2004
eetfunk's Avatar
Yep. 6.5 in the rear.
Old Aug 5, 2004
dooma's Avatar
dooma is an unknown quantity at this point
I about to buy new fronts for my coupe also - i realise that a spacer would be required but does this mean that the speaker will no longer fit under the stock grill cover in the door? It is part of the entire door trim. Does it fit even with speaker under full excursion (i.e. the cone doesnt hit inside of the door) and also can the windows still be fully brought down...cant be having my cigarette arm restin on a bit of glass now can i?
Was looking at the Alpine SPR176A 6.5" component set...any other suggestions within this price range (114GBP)
thanks
ad
Old Aug 5, 2004
eetfunk's Avatar
JL Audio, all the way! I listened to both, the JL are a much better deal. A little more expensive, but its worth every penny.
UltraHDGames
Jun 8, 2016 05:16 PM
68camerors
Sep 24, 2015 06:18 PM
Gsxtacy
Sep 12, 2015 01:09 AM
