Update: RSX CLUSTER CONVERSION...PICS INSIDE
Old Jul 19, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
ok guys its time for an update with pics, the other thread was getting long so i started a new one..i finally got the first bracket out ..its not the greatest looking but it wrks, this one is just to testing out where all the holes need to be drilled and what needs to be trimed on every other part that i will make from that mold...basicly a templet...
give me some time and ill explain what every thing is..
This is the bracket i made to hold in the new cluster, like i dais this is a ruff one and will be used as a templet..the others will be tons better..i was in a ruch to get the projects going since there is alot of wrk to be done..
Back side view of bracket
This how it will fit in the civc stock location
this is the btm side of the bracket...here this is where the two scrws will hold the cluster to the bracket..remeber the RSX clust mounts from under the dash and now the top like in the Vic.
Heres what she looks like with the bracket mounted to the cluster
This is the actual dash...not in a car of course with the front panel off..this one is my OEM one out of my car after makeing my new CF dash..bracket fits in perfectly...hole line up right for the guides and the screw hole r dead nutts for mounting it to the OEN dash.
In this pic you are looking at the factory pluges taken out of my OEM cluter ( that thing is useless now) the pluges have been pined up by ruben and wrk perfect with the RSX cluster..plugged it in and on the first run it worked like ****...good wrk ruben
Ok here is the problem as of now . Since not every one is going to want to chop apart there OEM cluster to remove there plugs need to make the kit wrk...new pluges need to made to make it a plug and play kit... here your looking at a few sample ideas i was running through the other night...one is made of fiber glass and ther i made of epoxy.. these plugs will slide right into the OEM harness located in the vics dash...once they r pin'd up of course
here you see the actual mold i had to make in order to make the plugs..i could tell you how this is done but then i would have to shoot you...
top veiw of mold being made
Remeber with out the plugs ..its not plug and play...for now we have to call tons of places to look for Civic clusters just to cut these suckers out of them...wich sucks cuz they want a grip of cash for them...which means a higher cost for you when we sell...but if all goes well with the mold makeing of the plug ruben can keep his cost pretty low...
All we need now is the bezl..as you can see in the pic below the RSX cluster sites higher then the vic's OEM and a gap needs to be filled on the btm...also the RSX cluster has different countours then the vics bezl....so i need to fab a new one and make a mold of it and were done..ill strt this this weeks and hopfully it will be done by sat...and I'll post pics of this as well.
ID:	33203   Click image for larger version
ID:	33204   Click image for larger version
ID:	33205   Click image for larger version
Name:	brket and cluster.jpg
ID:	33206   Click image for larger version
Name:	cluster in dsh 1.jpg
Name:	cluster in dsh 2.jpg
ID:	33208   Click image for larger version
Name:	cluster in dsh 3.jpg
ID:	33209   Click image for larger version
ID:	33210   Click image for larger version
Name:	mont screws.jpg
ID:	33211   Click image for larger version
Name:	plug mold 1.jpg
Name:	plug mold 3.jpg
ID:	33213   Click image for larger version
Name:	OEM pluges.jpg
ID:	33214   Click image for larger version
Name:	OEM plug temp2.jpg
ID:	33215   Click image for larger version
Name:	OEM plug temp1.jpg
Old Jul 19, 2004
dru106's Avatar
ThE CoRRupToR
My GOD!!! Is that sweet........ Dam Kazzie!!!!!!!
Old Jul 19, 2004
HondaLuver's Avatar
Its a celebration bitches!
dam
thats nice,
and ur baby mama is hot... H O T...
Old Jul 19, 2004
KaZeLL's Avatar
thanks for the comp on my babies momma temo, ya she is hot...Im loveing every minute of it to...haha
hard to belive but she was 8 months prego in that pic...haha
Old Jul 19, 2004
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
nice
Old Jul 19, 2004
AlpineCivic's Avatar
The cluster is nice bro!
Damn Is your baby's momma topless in that pic?
Old Jul 19, 2004
KaZeLL's Avatar
haha ya I had to do a little photo shoping to get the r rated label for that pic...haha...or other wise it would have been XXX...I got her a web cam one weekend so we could talk and see each other while she was at her house and i was at mine and she got a lttle crazy and took some pics for me...this is one of the cleaner ones...haha..dont want to get banned for ****....haha
Old Jul 19, 2004
How much for the cluster and the pictures? Package deal? hahahahha just kidding.
Old Jul 19, 2004
KaZeLL's Avatar
haha that was funny...only got one cluster for now...im selling for 350 bucks..Type R..and that only one i have to....get um while i have um...cuz there hard to find
...o buy the way that pick up price
Old Jul 19, 2004
HyaBoosta's Avatar
def. props. I wish i had the ***** to do that
Old Jul 19, 2004
abmerop18's Avatar
Jam out with your clam out.
great job man!! i'm defeniatly gonna look into buying this kit from you when it is ready to be sold!
Old Jul 19, 2004
abmerop18's Avatar
what doyou do about the odometer though? you would not want to get busted for odometer fraud, so you would some how have to find a way to set it to the current reading of your stock one.
Old Jul 19, 2004
KaZeLL's Avatar
TRYING TO FIGURE THAT OUT....one step at time though..for now i just wrote down the miles one my old cluster and where i started on the RSX ...you can do the math..besides its stored in the ECU..if some one really wanted to check...honda could tell you....but later i will figure it out..its not like there itching to tell you how to change the milage on the odom meter...haha
Old Jul 19, 2004
Probably the only way would be for a Honda dealer to change it for you.
PS: I want a copy of those pics hehehehe
Old Jul 20, 2004
KaZeLL's Avatar
well this was are first attempt at makeing the plugs for the harnest, ruben was being a little b^tch and had to see one befor he left my pad so we pulled the plug out to early from the mold so it came out kinda f^ck-up..but you get the idea...now i have to make another one ...this time with no rushing...
Every one thank ruben!
ID:	33325   Click image for larger version
ID:	33326   Click image for larger version
ID:	33327   Click image for larger version
ID:	33328   Click image for larger version
Old Jul 20, 2004
Em2Guy's Avatar
damn gangsta
Old Jul 20, 2004
DVnAFI's Avatar
Tiene tremendo...CULO!
DVnAFI is an unknown quantity at this point
isnt that stuff rosen?
Old Jul 20, 2004
HondaLuver's Avatar
^^^ shes hot!!!
Old Jul 20, 2004
Wolfgang5884's Avatar
looks really nice man
Old Jul 20, 2004
KaZeLL's Avatar
your just horny temo....haaha ..yes its rez well one part .....its a special brew...haha...
Old Jul 20, 2004
abmerop18's Avatar
is it going to be a plug or adapter you are making? are we gonna have to do any wiring of our own for that plug or is it just 'plug and play'?
Old Jul 20, 2004
alex053's Avatar
i have used stuff like that to make molds...the stuff i used was blue and you need a vacuum to get all the air bubbles out to make the mold...makes great molds though..
Old Jul 20, 2004
HyaBoosta's Avatar
does it work accuratly? cause of the higher redline? and calibration>?
Old Jul 20, 2004
Em2Guy's Avatar
it is indeed plug and play and does not enhance any calibrations. U will read same rpm and it will add milage as u would on ure stock one. It will not keep ure stock milage though. if an accurate milage reading id needed the dealer can get it off the ecu for u
Old Jul 20, 2004
Mike4831's Avatar
Mike4831 is an unknown quantity at this point
thats is some hardcore stuff. looks good.
Old Jul 21, 2004
HondaLuver's Avatar
im not horney, just sexually fustrated...
Old Jul 21, 2004
KaZeLL's Avatar
i would be to if i beat it as much as you do temo...hahah
yes ruben is right it is plug and play, thats why were makeing the plugs r selfs..if not you would need to rip apart your OEM clustr to get these plugs... Nothing will be affected buy the new cluster..it will all wrk the same just as befor...
milage is stored on the cluster itself....were trying to figure out how to pinpoint where exactly this is at on the RSX cluster so we can mod it to read your curent mileage...when we do will let you know...
Old Jul 21, 2004
gh0st's Avatar
TAQUITOS!!!!
looks nice so far. hope everything goes good!
Old Jul 21, 2004
W1LLY_G's Avatar
ttttttt
Old Jul 21, 2004
looks real nice
