'03 Civic EX turns into Christine
Old Jul 16, 2004
Jumper_Ed's Avatar
Jumper_Ed is an unknown quantity at this point
Howdy. I'm new here. My wife’s' 03 Civic EX has turned into Christine and developed a mind of its own. The car has about 15k miles and it has some serious electrical issues. Today the power door locks stopped working, the intermittent wipers don't work with the switch although the wipers will move on their own with the switch in the off position. When you hit the power door lock switch, the instrument cluster lights will flash on and off. When you turn on the emergency flasher / hazard switch, there is a buzzing noise from under the dash. The turn signals don't work, the indicators on the cluster will not even light up. The power windows work intermittently. Has anyone else had electrical issues with their 2003 Civics? The car is at the dealer now and they gave me a loaner CRV to play with until her car is fixed.
Old Jul 16, 2004
tacheon's Avatar
tacheon is on a distinguished road
Your body control module is probably dead. I got an 2003 LX. I got an engine component replaced. Nothing as severe as your problems.
Old Jul 16, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Or.... look for a loose ground connection. Honda connects all the wire harnesses to common ground points. There are some under the hood, and under the dash. There's also one in the trunk, but you don't seem to have problems there. I'd check all the ground points before doing anything else. It'll be a bolt with a bunch of wires under it.
Old Jul 23, 2004
Jumper_Ed's Avatar
Update on '03 Civic EX electrical issues
Ok, the car has been fixed. The dealer called on Monday and said it was the multiplexer control unit and it would take two days to get the part. The part came in on Thursday and the dealer installed the multiplexer and that didn't fix it. Apparently, there was a loose ground connection under the bumper but they didn't tell me if it was under the front or rear bumper but they said they had to pull the bumper off the car to get to the ground point. Thanks for the replies about this issue. I hope this helps someone down the road.
Old Jul 23, 2004
djmota's Avatar
wow wild stuff for a fairly new car, glad to hear the dealer took care of you.
Old Jul 24, 2004
tinman's Avatar
HAH! Loose ground does it again!
shaejb15
Apr 26, 2015 07:44 PM
McD
Apr 22, 2015 05:28 PM
GH04si
Apr 15, 2015 08:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
