Making our stock intake cold air?
Old Jul 12, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
Just below the inlet to the intake is a square hole with some wires running thru it. Has anyone fabbed a piece to go into it and then onto the stock resonator box opening? Not the air filter box opening for clarification.
Old Jul 12, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Pics? Please?
Old Jul 12, 2004
It already drawing cold air from where the intake is next to the battery. You won't feel any difference by running longer pipe down to the bumper.
Old Jul 12, 2004
redvtec04's Avatar
VTEC MASTER
Thats what I thought, but you never know...
Old Jul 12, 2004
518's Avatar
518
518 is on a distinguished road
GanzFlow Design
Old Jul 12, 2004
That design is stupid. It's the same as the stock setup, only you'll have an ugly tube and louder sound without resonator.
I think the question we should be asking is how to make the air colder that's going into the stock inlet. It may be possible to just replace the stock inlet from the resonator down to the bumper someplace. But then it's gonna get dirty and suck more dirt in. Oh well. I think Honda spent more time on design than anyone else could.
Old Jul 12, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
"only you'll have an ugly tube and louder sound without resonator."
Sounds like most of the aftermarket intakes... ;-)
Old Jul 13, 2004
Haha. I've found that my car pulls harder with the stock intake than with K&N or AEM intakes. It has to do with the airbox acting as a reservoir to make sure there is a constant flow even at low rpms.
You have to remember that the car needs a combo of both velocity and volume of air. Too big a tube will give more volume, but then the speed will decrease. Too small an opening, and you'll get less air moving at a faster rate. So the stock design is sortof a compromise to this.
Old Jul 13, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
Isn't this the whole idea of the V2?
I'm not sure...but I think the V2's claim to fame is that it pushes MORE air...FASTER....
Just thinking about my EP3. A friend has the AEM CAI/Magnaflow exhaust...and I'm NOT impressed. I've beat him 3 times, and I'm ALL stock. So...this holding true...I intend to STAY stock, keep my torque, and have more pull at low RPM's for AutoXing................whatcha think Gbox?
I've also thought about the V2 because of the above "claim to fame"...more/faster.
(Remember, I have the K20A3...not the D17...)
Old Jul 18, 2004
Stay stock. Or maybe look for a way to extend the intake inlet to make it get colder air. This may be possible on a civic, by replacing just the inlet while keeping the airbox and resonator. There's no room though. I'm finding that the best mods are those that do not involve a complete replacement. The ported head I have seems to be doing okay, and I may get the TB bored out as well for a bit more response.
Old Jul 18, 2004
FattyMcJ's Avatar
Hmm....yeah. After my AutoX event today....I'm not doing ANYTHING to the motor...until I can do it all, I/H/E, all at once. To salvage some torque while gaining the hp.
But we'll see....
Thanks for the input!
Old Jul 19, 2004
RallyeRed2k2's Avatar
RallyeRed2k2 is an unknown quantity at this point
i have exhaust on my car, should i not get intake then, is that what your saying?
Old Jul 19, 2004
FattyMcJ's Avatar
Not necessarily...you've already started the process...just finish it.
Old Jul 21, 2004
We really need to find a way to cool the entire intake system. Those plastic pieces get very HOT. So even if you're drawing in cold air, it will be 100+degrees by the time it reaches the TB. We need better engine bay cooling I guess. I felt the intake today and almost burned myself on it.
Old Jul 21, 2004
jgoodfella1's Avatar
jgoodfella1 is an unknown quantity at this point
I've been considering this also gearbox. I think I am going to wrap my fipk you sold me in refelective insulation. I was also thinking about mounting some small cooling fans in the engine bay around the intake area. Maybe like a 4 inch fan conected to some tubing routed down kind of like a cai. It would have like a ram air effect when driving and the fan would pull cold air in when at a stop. The fan could be hooked up to a thermostat. I'm not sure how it would all work but I'm starting with the insulation wrap.
Old Jul 22, 2004
Wouldn't the power used to run the extra fans diminish any gains in horsepower?
Old Jul 22, 2004
The wrap will help, and that heat shield around the filter also does a good job. It's the stock intake that's harder to do.
Old Jul 22, 2004
It would depend on the size of the fan. a 4 inch fan can run off of 4 AA batteries so I don't think it would use too much juice especially for me cuz I don't have any I.C.E. I'm just brainstorming some ideas. I think the intake will stay fairly cool when driving if I just route some type of tubing to the grill and make it like ram air. The problem is keeping it cool in stop and go driving or when stopped at a red light.
Old Jul 22, 2004
redvtec04's Avatar
VTEC MASTER
Talk about fans sapping power! The older cars with the clutch fans robbed a ton!!!
Old Jul 22, 2004
Yeah, my dad used to have a 69 chevelle. We got rid of the fan clutch and bought a flex fan.
Old Jul 23, 2004
Our fans use alot of power to run, and they don't even cool that well. The problem is the tranny and header both give off tons of heat that gets caught by the plastic intake parts. Sure the inlet on the side is nice and cold, but the other pieces are super hot.
Old Jul 23, 2004
FattyMcJ's Avatar
Here's and idea.....
JUST TAKE OFF THE HOOD!!!
ROFLMAO....eh...it's an idea.....
Old Jul 23, 2004
Yea... I actually see people do that from time to time. I think i'm just going to weld a huge piece of sheet metal around the whole engine except for the intake. Problem solved! Or since our TB is on verticle mount I could just cut a hole in the hood and run a pipe straight up through the hood and the filter could stick up in the air like a flag or something. I'm gonna invent an engine that runs off ice water.
I am filled with ideas problem is none of em work.
jc33312
May 12, 2015 03:17 PM
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
Gl3n1234
Apr 18, 2015 01:51 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
