RSX 19mm rear sway bar
Hi dudes, this may sound like a repost, but I would like to confirm with you guys about the above. Is there a significant or even a little bit of body roll reduction with the RSX 19mm sway bar installed ? I would get it if there is definitely a reduction in body roll regardless of the amount. Hope you guys with the bar can share some experiences. I have searched the forum, but nothing much mentioned about body roll reduction in the front end. I feel that i have significant roll couple differences in the front and rear. I feel that the front twists more than the rear when I drive over uneven grounds. Will the RSX rear sway bar reduce this ? Thanks.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
muniorbust
33
Aug 31, 2015 08:59 PM
