6900RPM fuel cut???
Old Jun 30, 2004
HyaBoosta's Avatar
Question 6900RPM fuel cut???
Hey I read on a thread by opto isolator that our fuel systems begin to cut the fuel at about 6900 rpm. so running the gear till 7200 would be a waist of time right? does anyone know if this is true? what would be the sweet spot shift point for our vics? EX that is??
Old Jun 30, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
the rev limiter kicks in at 7000, so I doubt the fuel cuts off before then. I don't know. If you really want to run up to 7200, I'm sure there's a way to disable whatever Honda cutoffs there are. Be sure you upgrade your valvetrain so you can handle the extra RPM's though.
Old Jun 30, 2004
NoFriends's Avatar
I like ruining your threads.
Fuel cut off is 7200, you can rev to that without any modifications.
Old Jun 30, 2004
HyaBoosta's Avatar
but can you really pull any more power out of taking it to 7100-7200
anyone know a really good rpm shift point?
Old Jun 30, 2004
jwalker87's Avatar
Bodacious Member
HP peak is at 6300. I shift as close to 7k as I can get without hitting the rev limiter.
Old Jun 30, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
sorry but our fuel cut is at 7000 for an EX. You may see 7200 though because your stock tach is off.
Old Jul 1, 2004
jwalker87's Avatar
Bodacious Member
arent stock tach's supposed to be terribly inaccurate over about 5k rpms? And the speedo is pretty bad over like 80?
Old Jul 1, 2004
doubledeuce2k2's Avatar
try having an engine in that has 7900rpm fuel cut off... i've gone up to what it says is about 8200rpms on my k20a2 without getting to fuel cutoff.
and the purpose of going beyond where you make more power is that when you shift, you are in the better part of the power band. best point is as high as you can w/out getting to cutoff
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
mistermenphis22
Jul 13, 2015 04:43 PM
